Astonished free mechanical prog
 1-8  9-28  29-48  49-68  69-75
6186.49 In reply to 6186.48
Maui,
Dimension the part in MoI with max's dimension script. It will make dimension geometry, not the special dimension blocks. Save time.
6186.50 In reply to 6186.49
Hi @BurrMan, I'll have a look...
Don't returned to this one for a while!
DesignSpark Mechanical
It's now 4.0 totally free with all powerful functions present!
Install is very long so be patient!
Register is only mail + password! Multi-languages! Free!
So a SpaceClaim light!
https://www.rs-online.com/designspark/mechanical-download-and-installation
Boolean functions and powerful fillets!
Old powerful functions disapeared are come back!
EDITED: 29 Jan 2019 by PILOU
Launch the V 4.0 , close the Home Page arrived inside the prog
import the MOI file STP in the V 4.0 (Menu File "Open")
The Format STP is "only read" but...
... use the same old trick!
Go to the head of the arborescence, draw a 3D SPhere
and Right click on the head arborescence then click the enabled case Lock for "unclick it" !
And have fun direct modeling!
All will works fine! :)
Else direct importation SKP format works fine in the DSM V 4.0! ;)
It imports not textures, only color and name Group/component arborescence!
Always tricky for go from DSM 4.0 to Moi 3D! ;)
Save in native format MyObject.rsdoc inside DSM
- rename it in MyObject.zip
- unzip and search inside the Unzipped folder a file .sab inside folder SpaceClaim / Geometry
so something like part1bodies.sab
Say you put part1bodies.sab in a folder Pifou on your Desktop
Just type the 2 following lines (in a single "command line" ) replace of course Pilou by your user name! :)
( Key Logo Windows + R)
"C:\Program Files\DesignSpark\DesignSpark Mechanical 4.0\SabSatConverter.exe" -i "C:\Users\Pilou\Desktop\Pifou\part1bodies.sab"
-o "C:\Users\Pilou\Desktop\pifou\MyBeautifulObject.sat"
You can now reload the file inside Moi3D! :)
That all! :)
I am affraid the inverse Moi3D to DSM will be not so simple! In fact yes : just use the Step file format! :)
For any file stp to DSM
Launch the DSM V4.0
Load the file ".stp"
And make the little tricky create "Sphere 3D" and unlock on the top arborescence! (as seen some post above)
That's all! :)
the file step created in Moi3D
Inside DSM
EDITED: 3 Mar 2019 by PILOU
Always fun to use! :)
EDITED: 22 Jan 2019 by PILOU
"Step" files from Moi are good for direct importation!
(but the trick of the Sphere "unlocked" always indispensable for modify it inside DSM - 2 seconds! ;)
- Direct export save as STL, OBJ, SKP works fine!
- Only nurbs format Sab / Sat should have the trick of the "command line" shown above! (5 seconds) :)
PDF 3D...seems always not visible but maybe i forgotten something again! :)
(and i am not sure to have always a pdf 3D viewer! If you have a Pdf 3D on line...
(or use the V 1.0 collector : http://designspark5.rssing.com/chan-33180489/all_p3.html
EDITED: 23 Oct 2019 by PILOU
With Magica...!
Winter-Spring
Message 6186.58 deleted 23 Jan 2019 by MKDM
6186.59
I wish editing finished models in MoI would be so easy as in DSM. Or MoI have some sort of easier part edit.
EDITED: 10 Feb 2019 by MR_JURAJ
6186.60 In reply to 6186.53
This isn't working for me. I converted the sab file successfully ( as far as i know) but then it doesnt open in moi. Can you take a look at this sab and sat file and make sure it works for me? i would appreciate it a lot! :)
6186.61 In reply to 6186.60
Hi JerryBerry, your Converted.sat file comes in ok with the current MoI v4 beta, you can get it from http://moi3d.com/beta.htm .
One thing that's a little odd is the units are in meters so the object is of a small numeric size. You may be able to get it openable in MoI v3 if you can get the .sat file to be generated using an older version of the .sat format like version 8 or something like that. That will then make the .sat file use more general NURBS surfaces and curves for things rather than newer specialized entity types.
Here's what it looks like loaded into MoI v4:
So working! Cool isn't it ? ;)
Adventure continues :)
Tested: Tips above always works! ;)
EDITED: 14 Sep 2020 by PILOU
Tested the new version 5.0 : all works fine ! :)
Import Export SKP etc...
Import STEP (from Moi for hard Fillets ;) Export SAT (with little easy tricky thing)
6186.65 In reply to 6186.63
Most sub $2000 MCAD's surface modeling are too weak, pretty useless for product design.
6186.66 In reply to 6186.65
It's for that this little free one is a little gem! :)
and it's making PDF 3D!;)
Here a PDF 3D From a Moi Volume
so you can use the PDF 3D for some dimensions in direct in your favorite 3D PDF Viewer!
6186.67 In reply to 6186.66
Not sure if this shows designspark have removed some import features over recent years:
http://help.spaceclaim.com/dsm/2.0/en/Content/Importing_and_exporting.htm
It lists autocad dxf. Click on blue autocad link and it will show dxf r12-r14, 2000 etc. (Import and export?!)
Can you confirm Pilou?
More comprehensive settings by file type here, click blue links at bottom of page:
http://help.spaceclaim.com/dsm/2.0/en/Content/File_import_and_export_options.htm
》》》》 Maybe all this is out of date as the "2.0" might be from 2014 and we are now on v5??
EDITED: 15 Sep 2020 by LIGHTWAVE
6186.68 In reply to 6186.67
I am only speaking about the Free version 5.0 without Exchange module $ !
We have only rsdoc, OBJ, SKP, Step, STL as import and PCB for electronic components
And for Export rsdoc, amf, dxf, Pdf, PDF 3D, GLB, OBJ, vdb, SKP, stl, xaml, jpg, PNG
and with my little tricks SAB & SAT ;)
and this following as Images Files import
EDITED: 15 Sep 2020 by PILOU
Show messages:  1-8  9-28  29-48  49-68  69-75
