edit an extruded part, .dxf file, dimensioning
All  1-2  3-4
6173.3 In reply to 6173.2
Hello Michael,
I completely missed editing with the properties panel size dropdown. Works great. Thank you.
parametrics was just curiousity.
Found a fix for the .dxf file conversion. CorelCad not the way. Found an old issue of TurboCad which works fine.
At least I had the dimensions right.
Thanks again. Sure glad I bought moi 3d from you. I'm have some good fun.
Your great.
ms
6173.4 In reply to 6173.3
No problem Marv!
It's probably possible to get CorelCAD DXF import working ok too, it's probably a matter of telling it which unit system the DXF file is set in, some programs don't know how to find the unit setting in the DXF file since it's kind of an obscure thing.
Also make sure when you do the DXF export out from MoI have your unit system in MoI set to what you need, don't leave it as "no unit system" since several other programs don't support that concept of a non-specified generic unit and may instead decide to use some other default like millimeters.
Show messages: All  1-2  3-4
