How to put lines exactly onto a surface?
All  1-19  20
6171.20 In reply to 6171.19
Hi Ditto,
> So if I can't temporarily change options, can I change them from within a running MoI instance?
With most settings you can do that by running a script. But these particular settings are not currently exposed to script, they're only read from the .ini file and there isn't any access to them from script so there is not currently any way of changing these particular settings from within a running MoI instance.
> In this example, there is this DisableOnSrfInOrtho option in the ini-file. Can I modify this from within
> MoI this without editing the ini-file? Using a shortcut, for example.
Sorry, no not this particular setting, it has not been set up to be accessible to scripts.
Show messages: All  1-19  20
