How to put lines exactly onto a surface?
All  1-15  16-20
6171.16 In reply to 6171.10
> [Drawing Aids]
> DisableOnSrfInOrtho=y
> Switch that to =n and then you should get the snap behavior that you want.
That would be nice to be able to toggle this behaviour with a shortcut. Can I temporarily change program options during runtime? By 'temporarily' I mean, options are changed, but not saved.
6171.17 In reply to 6171.16
Hi Ditto,
Your current settings are saved by MoI into moi.ini at exit time, so basically no there isn't any way to change a setting that's stored in moi.ini and not have it saved when you close the program.
6171.18 In reply to 6171.17
Hi Ditto,
One thing you can do though if you want to be able to easily revert back to some saved group of settings is to make a backup copy of your moi.ini file, then when you exit MoI copy the backup copy of it over onto the main moi.ini file again. That will then restore all settings.
You can find out where your moi.ini file is located by going to Options > General and push the "Edit .ini file" button, the dialog that pops up will tell you where the file is located.
6171.19 In reply to 6171.18
Thanks for the replies. So if I can't temporarily change options, can I change them from within a running MoI instance? In this example, there is this DisableOnSrfInOrtho option in the ini-file. Can I modify this from within MoI this without editing the ini-file? Using a shortcut, for example.
Thanks!
Ditto
6171.20 In reply to 6171.19
Hi Ditto,
With most settings you can do that by running a script. But these particular settings are not currently exposed to script, they're only read from the .ini file and there isn't any access to them from script so there is not currently any way of changing these particular settings from within a running MoI instance.
Sorry, no not this particular setting, it has not been set up to be accessible to scripts.
Show messages: All  1-15  16-20
