Hi 3image,
> Though, is it possible to make the movement in the 3d screen work in screen space orientation?
Do you mean for rotation? You can make rotation work relative to the view orientation by setting the option under Options > View > Rotate/Pan/Zoom options > "Rotation style" dropdown (at the top). Set Rotation style = "Free rotation" to use a view-relative rotation style, where left/right/up/down means left/right/up/down in viewing screen directions.
> Moreover, are there keyboard commands for the 2d screens as well?
For panning, you can make keyboard shortcuts that work on the active view (the view the mouse is over in split mode or the zoomed viewport in single view mode) by using the following:
| Key | Command |
| LeftArrow | script: moi.ui.getActiveViewport().pan( -0.2, 0.0, 0.0 ); |
| RightArrow | script: moi.ui.getActiveViewport().pan( 0.2, 0.0, 0.0 ); |
| UpArrow | script: moi.ui.getActiveViewport().pan( 0.0, 0.2, 0.0 ); |
| DownArrow | script: moi.ui.getActiveViewport().pan( 0.0, -0.2, 0.0 ); |
