Surface Tearing - Blend - v3 Aug1
6133.1
Hi Michael
I'm getting a tear in this multi select blend.
~Kevin~
Size: 58.3 KB, Downloaded: 146 times, Dimensions: 726x473px
6133.2 In reply to 6133.1
Hi Kevin - you'll have gaps like that in cases where the chain of edges comes to a sharp crease between 2 edge segments. In this case the sharp crease is where the 2 halves of your rudder come together, there is about a 10 degree deviation in the end tangents of the edges in that area.
A multi selection blend needs to have all of the edges be smooth to one another to generate just one surface as the output.
6133.3
Ok, thanks for the explanation Michael
Fortunately you've included extract isocurve and combined with loft-loose-exact works very well to give a nice blend between fuselage and fin.
~Kevin~
