Nsided Patch Problem - V3 Aug 1
All  1-7  8-19
6120.8 In reply to 6120.7
Thanks Michael !
Before last update i noticed choosing CUSTOM with default tolerance (0,01mm) allowed Network to follow exactly boundary curves
That's why i choosed immediately CUSTOM with Kevjon's patch....but now i know i can choose NORMAL thanks to this update
anyway...leaving apart my approximative explanation (in English).... i understood right :)
6120.9 In reply to 6120.8
Hi Mauro, so some additional specific details:
"Normal" mode actually uses the default relative tolerance (0.001 if your object is between 1 and 50 units in size, otherwise a fraction of the curve's bounding box size) for the outer boundary curves and 10 times that amount for the tolerance of the interior curves.
"Lighter" mode uses boundary tolerance of 15 times default tolerance for outer boundaries and 30 times default tolerance for inner boundaries.
"Custom" mode uses the value you set for both boundary and inner fitting tolerance.
"Uniform" mode uses the given number of sample points rather than doing a tolerance deviation based fitting.
Also if you are doing a 4-sided network with no interior curves, there is also an "Exact" setting available that uses the curves as-is (inheriting all curve structures into the result surface) with no refitting done at all.
6120.10
Thanks all, very useful information about the Network command in v3.
Having lots of trouble patching the wing/fuselage joint on the underside of the aircraft and making it all look smooth and seamless. So for now I head back to polygon modelling but will keep on eye on future development of MoI to see if tools become available that will solve problem areas like these.
EDITED: 16 Aug 2013 by KEVJON
Size: 33 KB, Downloaded: 49 times, Dimensions: 690x451px
6120.11 In reply to 6120.10
Forgive me Kevjon but i think it not depends by futures Moi's tools to solve your trouble
I mean you should consider a different approach to model that plane
Why split the fuselage in half ? You'll have the seam..difficult to join smoothly
Why that wide hole underside if the fuselage shape there, is not flat but curved?
Take a look at side wiew i highlighted with red arrows..you should model the whole fuselage with Loft or Network, following the jellow line i highlighted,THAN..trim fuselage and do the blend to join the wings
or..after whole fuselage,start to draw a wing section to trim fuselage than follow Samardac Method:copy first section and paste scaling them when needed to do the Loft...now you have also close to point option ;)
hope you'll understand what i mean
M
EDITED: 19 Dec 2021 by M-DYNAMICS
6120.12
Hi Mauro
The aircraft is P39Q Aircobra.
I've tried many different ways than the one posted to get a smooth transition between the wing and fuselage and try to make it look close to the real thing.
The fuselage is modelled as a whole following Samardac loft method except I used (normal-exact). I've just split it in half to to simplify the task of patching this area. Whether you are patching the whole area or just half, the issue is the same ?
> Take a look at side view I highlighted with red arrows..you should model the whole fuselage with Loft or Network, following the yellow line I highlighted,THAN..trim fuselage and do the blend to join the wings
The bottom of the fuselage needs to follow the contours of the underside of the wing, it doesn't have the bottom of the fuselage projecting through the contours except at the front and rear of the wing.
> point option ;)
> I have tried this way except the real aircraft does not have the contours of the fuselage projecting through underside of the wing. The fuselage shape instead flows smoothly into the contours of the wing >undersurface.
I'm really excited about the Samardac loose loft method & loft to point, however it doesn't allow seamless transition of two surfaces in two directions like patch or network.
I have attached the curves of the wing and fuselage if you could show me a nice way of getting the two to flow smoothly together on the underside of the wing would be greatly appreciated. I think it might be good learning exercise for others as well.
EDITED: 17 Aug 2013 by KEVJON
Size: 71.5 KB, Downloaded: 50 times, Dimensions: 694x499px
6120.13 In reply to 6120.12
Wish you luck with this kevjon,
I hope you find a solution as it is similar to the fin/fuselage challenge I had (unsolved) in the ...Organic Modelling of Glider Fuselage topic I started.
Cheers.
6120.14
@Argo
I don't know if this helps you but this is how I tackled the fin/fuselage joint. I used Network and blend.
Actually thinking about this more, I could probably get rid of the network and included that part in the loft of the fin shape.
I also tried Andrei's Loft-Loose-Exact for the whole fin including the fuselage fairing but it doesn't give tangency at the fuselage joint which results in undesirable shading highlights when converted to polygons and rendered. It really needs to be at least G1 blend to overcome the shading highlight errors.
Size: 57.3 KB, Downloaded: 52 times, Dimensions: 702x476px
6120.15 In reply to 6120.14
This is just to explore alternative ways :)
You could try to mirror wing sections and loft whole wing than move some points of yellow section until you have a better shape
my suggestion is also to pay attention how to manage points in wing sections
supposing you need to blend wing+fuselage surely it failed because wing is too sharp
avoid also to have the seam of the wing just in the sharpest part
use MarkCurveStart plug-in to control each section and move it in neutral position
red one is a section of your wing,blue one is how i managed points in that area:
avoid to put a point in the sharpest part,give more distance between them to have more rounded shape
this allows to blend or fillet to have more space available to work
M
6120.16
Hello,
Part of the issue may be that the edges and surfaces are causing more trouble due to the control point organization and complexity. After doing a few tests I've found you can get better surfaces by having less points that are placed well than more. It also may be harder since you are trying to create the entire surface in one piece. Perhaps some model planning would help so that you can create several smaller surfaces that exhibit good control point placement rather than trying to deal with one large surface. I don't think loft is going to get you where you want to be in this instance if you are looking for something past G1. Getting to at least G2 and having a nicely planned model should get alleviate some of the smoothing issues.
6120.17
@Mauro
That looks like it has some potential combined with a blend between fuselage and wing. I'll give that a go and post up the result, good or bad.
The extra point you show in the red curve (which is the way I did it) is so I can snap my wing profiles to guides to avoid having a wobbly leading or trailing edge to the wing.
hmm, good point. Perhaps I need to delete my snapping point after I have all the wing cross sections in place. It may help when doing the blend between fuselage and wing.
This is the shape I need to create on the underside of my wing. As you can see it is relatively flat under the wing.
@OSTexo
I'm more than happy for you to show me how to achieve better results with a better planned model and less points.
~Kevin~
6120.18 In reply to 6120.17
Ok, here is one way of tackling it. The white lines in the Network patches are G2 blend curves to try to keep continuity.
But after converting to polygons not too good.
~Kevin~
Size: 31.8 KB, Downloaded: 44 times, Dimensions: 180x463px
Size: 19.3 KB, Downloaded: 48 times, Dimensions: 425x361px
6120.19
Ok, I think this is bit simpler and gives a result that is good enough for my purposes.
What I learned in this exercise should stand me in good stead for other low winged aircraft.
~Kevin~
Size: 40.4 KB, Downloaded: 43 times, Dimensions: 375x452px
Size: 45 KB, Downloaded: 59 times, Dimensions: 800x600px
Show messages: All  1-7  8-19
