beretta cx4 storm
All  1-5  6-8
6118.6 In reply to 6118.5
Hi Andrei,
> You mean second surface only for hole? Or for area around it to?
The second surface is for the "side walls" of the hole - it would stick out and intersect the outer surface and you'd trim both surfaces with each other.
Then the area right immediately around the outside of the hole comes from filleting.
> This is not clear for me.
Basically cutting a chunk away from a larger block with a curved cutting surface something similar to this:
6118.7 In reply to 6118.3
Andrei:first a big loft to cover whole rifle
than imagine red and blue area like a single part to subtract (seems like a big sharp ellipse)
after subtract you can do handle and trigger also subtracting from previous shape
just a quick idea..
M
6118.8
Thanx guys, I'll try)
Portfolio: www.samardac.tumblr.com
Show messages: All  1-5  6-8
