Clines and value input
All  1-2  3-8
6117.3 In reply to 6117.2
Ok, I understand the missing "square" line. Having a snap target would be nice, as it would avoid having to enter the number twice.
For the second part, I am referring to the situation below. I can't get a snap at the height from the cline.
Ditto
Edit: Oupsa, I found my trick: Creating another, vertical, cline from the bottom of the rectangle and target the intersection. Not very evident, but I am a happy camper again. Thanks.
EDITED: 13 Aug 2013 by DITTO
6117.4 In reply to 6117.3
Hi Ditto,
That's working ok for me over here, have you possibly turned off some kinds of snap types? You would need "On" snap turned on if you want to snap on to just any point of that cline (not on any key intersection or end point I mean).
6117.5 In reply to 6117.4
2nd oupsa: You are right. Sorry for the noise.
Thanks, Michael!
6117.6 In reply to 6117.3
That shouldn't be necessary unless you have possibly disabled some other kinds of snaps?
6117.7 In reply to 6117.3
Also it looks like you did have a snap target that was enabled that you could have used here:
Notice that little faint tick mark there? Those show up on object snap points that are in the general wider area of the mouse cursor so that you can home in on them if you're looking for a snap point in that area.
6117.8 In reply to 6117.1
Hi Ditto, I've added in an additional "square" snap point for the next beta which will show up after you've entered in just one of width or height.
This affects the Rectangle, RectCenter, Plane, PlaneCenter, Box, BoxCenter, and ArrayGrid commands.
Show messages: All  1-2  3-8
