New Beta UI question
All  1-2  3-6
6092.3 In reply to 6092.2
Thank you, so I am saved for this time!
Just saying, for future versions it would be smart to update the structure of the moi.css, which could make it a lot easier to find&replace colors:
http://stackoverflow.com/questions/1875852/define-colors-as-variables-in-css
or http://css-tricks.com/set-up-variables-for-colors-in-css/
or even css variables, but I don't know if they work:
http://stackoverflow.com/questions/7247202/how-to-use-variable-in-css
That's just an idea, hope it helped.
M.
6092.4 In reply to 6092.3
Yup in the future I want to make a custom parser that will be able to set up some color defines in a text file, like:
#define SIDE_PANE_COLOR rgb(0,0,0)
etc... and then have only those labels in the moi.css file. That should make it easier to make a custom skin by only editing all colors in one single place.
I'm not sure when it will happen though, I have more of a priority on improving modeling tools rather than improving UI tweaking tools right now.
6092.5 In reply to 6092.4
Michael:
I use the phenomenon of crash, can't operation, can't save, can you tell me how to solve?
Size: 49.9 KB, Downloaded: 68 times, Dimensions: 631x409px
Size: 49.9 KB, Downloaded: 40 times, Dimensions: 631x409px
Size: 90.1 KB, Downloaded: 61 times, Dimensions: 445x306px
6092.6 In reply to 6092.5
Hi Beetle, that's a kind of weird crash. But I see from your dialog title there that you're using the Mar-17 v3 beta. I've just released a brand new one a couple of days ago, please try downloading the new one from http://moi3d.com/beta.htm and see if that one works better for you.
Also the moi_report1.zip file that you attached is of zero size, that may indicate that your problem is related to running out of memory. If MoI runs out of memory while trying to do some operation it could have weird side effects and also not generate proper crash reports as well.
If you are working with a particularly heavy file that is close to running out of memory there are some display settings you can adjust to reduce memory consumption, go to Options > View > "Meshing parameters" and change the "Mesh angle" setting to 25 degrees, and uncheck "Add detail to inflections".
That will make a rougher looking display mesh but will also reduce memory consumption by quite a bit on heavy files.
The default display settings generate pretty dense display meshes which look nice but can consume quite a bit of memory if you have a lot of little curved pieces or just a very dense model.
Show messages: All  1-2  3-6
