moi ui not functional on retina display macbook pro running windows 8.1
All  1  2-3
6089.2 In reply to 6089.1
Are you running MoI v2 there? If so then there's probably some issue with Internet Explorer, MoI v1 and v2 used the Internet Explorer display engine for displaying it's UI and if you've done something like installed the beta release of IE11 that may be incompatible right now.
MoI v3 has been significantly changed to not require IE for the MoI UI any longer, so if you use v3 instead that may work ok for you.
You can get the current v3 beta here: http://moi3d.com/beta.htm
6089.3 In reply to 6089.2
I just upgraded to v2 from v1. been away for a while. got a lot of catching up to do in moi :)
I just installed version 3. works like a charm!
Show messages: All  1  2-3
