CAIC WZ-10
All  1-3  4-17
6080.4 In reply to 6080.3
Andrew, Very cute, COOL!! You best! :)
6080.5
Thanx Grass)
Here is new video, and the result of the work.
As you can see all surfaces are smooth and as result of using LOFT there are minimum seams.
I tested new BLEND it works great, and LOFT to point also works good.
Image Hosted by ImageShack.us
6080.6 In reply to 6080.5
The shell of the chopper looks great Andrei
Just one question, did you manage to keep all your cross sections (for lofting) with equal number of points ?
~Kevin~
6080.7 In reply to 6080.6
Thanx)
Yes in most cases I try to keep the same amount of points. After I made object with loft, I start last stage where I make all curves with the same amount of points and align all points. To make surface perfectly smooth. In video I accidentally do not record this stage. I hope I'll make tutorial soon.
EDITED: 3 Aug 2013 by ANDREI SAMARDAC
6080.8 In reply to 6080.7
Really clean model
agree also with management of points..i do the same !
M
6080.9
Hi Andrei
I think you might consider making the front winglet a different way. Probably as a separate piece to the fuselage with a lofted blend.
The front and rear of the winglet has lost its airfoil shape when lofted with the fuselage which makes it look quite blocky.
I hope my observation helps you when you present the model to the client.
Thanks for the response regarding number of points. I assume you just use the add point command or select a point and hit the delete key till they are all equal.
~Kevin~
6080.10 In reply to 6080.9
kevjon,
Yep, I'll try to fix it. I tried to make it with loft and blend but do not like result, if you will watch video you will see it. Looks like I just have to tune a bit profiles of loft to make wings more round.
Yes I just add/delete points.
Portfolio: www.samardac.tumblr.com
6080.11
Continue to keep seams as few as possible. This time used a lot of revolve.
EDITED: 4 Aug 2013 by ANDREI SAMARDAC
6080.12
Hay people!
Model is finished - about 16 hours of work!
Total amount of edges is 3075. So small amount of edges allows me to work during all project with: Mesh angle - 10 and Add detail to inflection - ON.
Some details:
As you can see all edges are smooth no need for fillet at all, it is result of using LOFT, Rail Revolve and Revolve. I used fillet in this model only where I connected surfaces. A lot of times I used BLEND it works REALLY great!
And shaded view:
As you can see on shaded view it looks perfectly smooth!
Now time for Painting!
VIDEO:
EDITED: 5 Aug 2013 by ANDREI SAMARDAC
6080.13 In reply to 6080.12
It turned out great Andrei!
6080.14 In reply to 6080.12
Will be good to see it rendered up with full materials applied
Martin Spencer-Ford
6080.15
Thanx, Michael)
TpwUK, I'll start to paint it on days)
6080.16
That came out really well Andrei, great work !
~Kevin~
6080.17 In reply to 6080.16
kevjon, thanx)
Show messages: All  1-3  4-17
