Explodemove
All  1-3  4-5
6061.4 In reply to 6061.1
Hi Alex, sorry there is not currently any way set up to run ExplodeMove only in 2 axis directions.
The things Pilou mentions above are for setting the projection of the 3D view to make it be an axonometric view directly, so you could then see your result in the regular 3D view rather than only just trying to arrange geometry in 2 dimensions only. Does that help do what you need?
Otherwise if you need to make some kind of exploded view and ExplodeMove is not sufficient, you would need to arrange the pieces yourself. You might also want to check out some other CAD programs like SpaceClaim or Alibre, they may have better functions for generating those kinds of views for you.
6061.5 In reply to 6061.4
Thank you Mickael, I would like do an explode move but in two axis in same time, so I managed it object by object.
Thanks for your answer
alex
Show messages: All  1-3  4-5
