Samardac Method
 1-19  20-39  40-50
6058.40
Thanx Pilou, but a lot things changes till that time, this is my curent shortcut list from .ini with script description. First of all, I have very custom scripts for show/hide system and style/object systems.
I use very few plugins just these:
DistortCurves
MultyIso
Pipe2
[Shortcut Keys]
\'=AddPoint
,=Offset
-=Rectangle
.=shell
/=inset
0=circle
1=moi.ui.mainWindow.viewpanel.mode = 'top'
2=moi.ui.mainWindow.viewpanel.mode = '3d'
3=moi.ui.mainWindow.viewpanel.mode = 'front'
4=moi.ui.mainWindow.viewpanel.mode = 'right'
5=Line
6=Polyline
7=Curve
8=rectangle
9=RectCenter
\;=ShowPoints
\==RectCenter
\\=spherer4
`=script: /*Hide selected ---`*/ moi.geometryDatabase.getSelectedObjects().setProperty( 'hidden', true );
A=mirror
Alt+`=script: /*! Assign Hidden style and hide --- Alt+`*/ var st = moi.geometryDatabase.findstyle('Hidden',1).index; var obj = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < obj.length; ++i) { obj.item(i).styleIndex = st;}; moi.geometryDatabase.getSelectedObjects().setProperty( 'hidden', true )
Alt+A=ArrayGem
Alt+B=script: /*! Extend selection to the same object name --- Alt+B*/ var names = new Array(); var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' ) names[obj.name] = true; } objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' && names[obj.name] ) obj.selected = true; }
Alt+C=intersect
Alt+F=chamfer
Alt+F2=script: /* Toggle background image transparency between 85 and 100 */ moi.view.backgroundImageTransparency = (moi.view.backgroundImageTransparency == 85? 100 : 85);
Alt+F5=export C:\Users\samardac\AppData\Roaming\DigitalFossils\NVil\Media\Clipboard\ClipboardObj.obj
Alt+G=scale 2d
Alt+H=script: /*! Show edges on selected objects, hide edges on all others --- Alt+H*/ var breps = moi.geometryDatabase.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) { var brep = breps.item(i); brep.getEdges().setProperty( 'hidden', !brep.selected ); }
Alt+M=merge
Alt+O=loft
Alt+Q=script:moi.view.resetCPlane();
Alt+R=RotateAxis
Alt+S=script: /*! Save screenshot --- Alt+S*/ var img = moi.view.screenshot( 'viewpanel', false ); var name = img.getSaveFileName(); if ( name != '' ) img.save( name );
Alt+T=script: /*! Open Add new style dialog --- Alt+T*/ var gd = moi.geometryDatabase; gd.styleEditorOpened(); var dialog = moi.ui.createDialog( 'EditStyleDialog.htm?titleid=Add style dialog title&index=-1', '', moi.ui.mainWindow ); if ( dialog.window.doModal() != -1 ) { var styles = gd.getObjectStyles(); if ( styles.length> 0 ) moi.ui.propertiesPanel.editStyleIndex( styles.length - 1 ); } gd.styleEditorClosed();
Alt+V=script: /*! Change light position --- Alt+V*/ var dir = moi.view.lightDirection; if ( dir.x == 1 && dir.y == 1 && dir.z == -1 ) { dir.set(-0.5,1,0); } else { dir.set(1,1,-1); } moi.view.lightDirection = dir;
Alt+W=script: /* Show curves with same style as any current selected object */ var styles = new Array(); var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); styles[obj.styleIndex] = true; } objs = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( styles[obj.styleIndex] ) obj.hidden = false; }
B=script: /*! Assign unique object name to selection and hide --- B*/ var all_objects = moi.geometryDatabase.getObjects(); var used_names = new Array(); for ( var i = 0; i < all_objects.length; ++i ) { var obj = all_objects.item(i); if ( obj.name != '' ) { used_names[obj.name] = true; } } var counter = 1; var name; while ( 1 ) { var numtag = counter.toString(); while ( numtag.length < 4 ) { numtag = '0' + numtag; } name = 'object_' + numtag; if ( used_names[name] ) { ++counter; continue; } used_names[name] = true; break; } moi.geometryDatabase.getSelectedObjects().setProperty( 'name', name ); var st = moi.geometryDatabase.findstyle('Hidden',1).index; var obj = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < obj.length; ++i) { obj.item(i).styleIndex = st;}; moi.geometryDatabase.getSelectedObjects().setProperty( 'hidden', true )
Backspace=cylinder
C=chamfer
Ctrl+1=ArrayCircular
Ctrl+2=ArrayDir
Ctrl+3=ArrayCurve
Ctrl+`=script: /*! Show all except curves, points and Hidden style --- Ctrl+`*/ var obj = moi.geometryDatabase.getObjects().getBReps(), st = moi.geometryDatabase.findstyle('Hidden',0), sti; if (st) {sti = st.index;} else { sti = 'nf';} for ( var o = 0; o < obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};
Ctrl+A=script /* select all*/:moi.geometryDatabase.selectAll();
Ctrl+B=script: /*! Assign unique object name to selection --- Ctrl+B*/ var all_objects = moi.geometryDatabase.getObjects(); var used_names = new Array(); for ( var i = 0; i < all_objects.length; ++i ) { var obj = all_objects.item(i); if ( obj.name != '' ) { used_names[obj.name] = true; } } var counter = 1; var name; while ( 1 ) { var numtag = counter.toString(); while ( numtag.length < 4 ) { numtag = '0' + numtag; } name = 'object_' + numtag; if ( used_names[name] ) { ++counter; continue; } used_names[name] = true; break; } moi.geometryDatabase.getSelectedObjects().setProperty( 'name', name );
Ctrl+C=CopyClipboard
Ctrl+D=ShrinkTrimmedSrf /*! Shrink trimmed surface --- Ctrl+D*/
Ctrl+E=script:var a = moi.command.lastCommandRevisionStart; var b = moi.command.lastCommandRevisionEnd; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.selected = true; }
Ctrl+F=flip /*! Flip normal of surface --- Ctrl+F*/
Ctrl+F3=script:moi.ui.createDialog( 'Plugins.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' )
Ctrl+M=script: /*! Show naked edges --- Ctrl+M*/ var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
Ctrl+N=New
Ctrl+O=Open
Ctrl+P=pipe2 /*! Pipe --- Ctrl+P*/
Ctrl+Q=SelectOuterLoopsAndDelete /*! SeparateSelectOuterLoopsDeleteTrim - Ctrl+Q*/
Ctrl+R=Rebuild /*! Rebuild curves --- Ctrl+R*/
Ctrl+S=Save
Ctrl+Shift+C=CopyClipboardWithOrigin
Ctrl+Shift+V=PastePart
Ctrl+Shift+Z=script: moi.command.redo();
Ctrl+Space=script: /*! Show subset of hidden objects --- Ctrl+Space*/ moi.geometryDatabase.showSubset();
Ctrl+V=Paste
Ctrl+W=script: /*! Select all curves --- Ctrl+W*/ moi.geometryDatabase.getObjects().getCurves().setProperty( 'selected', true );
Ctrl+X=Cut
Ctrl+Y=script:moi.command.redo();
Ctrl+Z=script:moi.command.undo();
D=BooleanDifference
Delete=Delete
E=extrude
F=fillet
F1=flow
F10=PlanarSrf
F11=script: /*! Toggle 3D view between parallel and perspective --- F11 */ var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = (vp.projection == 'Perspective' ? 'Parallel' : 'Perspective');
F12=script: /*! Set Cplane from view --- F12*/ moi.view.setCPlane( moi.ui.mainWindow.viewpanel.getViewport('3D').targetFrame );
F2=script: /*! Stright snap on/off --- F2*/ moi.drawingAids.straightSnap = !moi.drawingAids.straightSnap;
F3=script: /*! Object snap on/off ---F3*/ moi.drawingAids.objectSnap = !moi.drawingAids.objectSnap;
F4=image /*! Image ---F4*/
F5=paste
F6=blend
F7=Revolve
F8=RailRevolve
F9=align
G=Scale1D
H=script: /*! Show/Hide edges --- H*/ var breps = moi.geometryDatabase.getObjects().getBReps(); var hide = true; for ( var i = 0; i < breps.length; ++i ) { var edges = breps.item(i).getEdges(); if ( i == 0 ) hide = !edges.item(0).hidden; edges.setProperty( 'hidden', hide ); }
I=script: /*! Expand selection over same styles --- I*/ var objects = moi.geometryDatabase.getObjects();var styles = new Array();for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.selected ) styles[obj.styleIndex] = true; } for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( styles[obj.styleIndex] ) obj.selected = true; }
J=join
K=separate
L=script:/*! Select edge loop --- L*/ var gd = moi.geometryDatabase; function sl(o) { for ( var i = 0; i < o.length; ++i ) { o.Item(i).selected = 0; var e=o.Item(i).getEdges(); for ( var j = 0; j < e.length; ++j ) e.Item(j).selected = !e.Item(j).selected;}} gd.selectLoop(); var so = gd.getSelectedObjects(); var e = so.getEdges(); sl(so.getFaces()); sl(so.getSolids()); so.getBReps().setProperty('selected',0); e.setProperty('selected',1);
M=BooleanMerge
N=Copy
O=script: /*! Expand selection over same styles and loft --- O*/ var objects = moi.geometryDatabase.getObjects().getCurves(), points = moi.geometryDatabase.getObjects().getPoints(), styles = new Array(); for (var i = 0; i < points.length; i++) { objects.addObject(points.item(i))} for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.selected ) styles[obj.styleIndex] = true; } for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( styles[obj.styleIndex] ) obj.selected = true; }; moi.command.execCommand( 'loft' );
P=project
Q=script: /* Set Cplane*/ moi.view.setCPlaneInteractive();
R=Rotate
S=sweep
Shift+1=script:moi.ui.createDialog( 'moi://ui/ScriptPalette.htm' );
Shift+2=script: /* Opens Lighting Options Dialog */ moi.ui.createDialog( 'moi://ui/LightingOptions.htm' );
Shift+C=Silhouette
Shift+Space=script: /*! Invert view --- Shift+Space*/ moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
Space=;script: /*! Reset view ---Z */ moi.view.resetAll();
T=script: /*! Asign style --- T*/ moi.ui.propertiesPanel.editStyleIndex( moi.geometryDatabase.addStyle().index );
U=BooleanUnion
V=Move
W=script: /*! Hide unlocked curves and points --- W*/ function hide( objs ) { for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( !obj.locked ) { obj.hidden = true; } } } hide( moi.geometryDatabase.getObjects().getCurves() ); hide( moi.geometryDatabase.getObjects().getPoints() );
X=script: /*Show/Hide hidden linesf --- X */ moi.view.showHiddenLines =! moi.view.showHiddenLines;
Y=trim
Z=script: /* Solo */ var mgd=moi.geometryDatabase; if (mgd.getSelectedObjects().length> 0) { mgd.invertSelection(); var obj=mgd.getSelectedObjects(); for (var o=0; o<obj.length; ++o) { obj.item(o).hidden=true; obj.item(o).selected=false; }}
6058.41 In reply to 6058.40
Excellent!
6058.42 In reply to 6058.40
So many useful shortcuts.
Thanks for that list!
6058.43
Some Tips and Tricks.
Used scripts:
-DelCorners (Download: http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=e0fc8aca1fc5b69addf1d3ed91421181&filename=DelCorners.js)
-UnwarpCurve
-Pipe2
1
EDITED: 2 Sep 2014 by ANDREI SAMARDAC
6058.44 In reply to 6058.43
cool!
6058.45 In reply to 6058.44
Thanks Pilou!
And the another way to make this kinf of pipes, without FLOW. I think it is more nice method.
3
6058.46
Great stuff Andrei!
The DelCorners script is very useful as well. Installed it right away.
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
6058.47 In reply to 6058.45
Andrei Thanks for all these video tutorial...I'm watching them on Youtube! They're really nice! Thanks a ton
Ciao
Arian
Arian DESIGN
www.arianshamil.com
6058.48
Samardac Method Hotkeys:
Doesnt Work anymore !?
Is there a new Script available for hiding and showing Edges on an Object per toggling ?
6058.49 In reply to 6058.48
Hi ndrakey,
That's the script i use to toggle the edges visibility on the selected entities (surfaces or polysurfaces/solids) :
script: /*! Show-hide edges on selected objects */var breps = moi.geometryDatabase.getSelectedObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) {var brep = breps.item(i);brep.getEdges().invertProperty( 'hidden');}
It works for me.
Nice day,
Marco.
6058.50 In reply to 6058.48
Hi ndrakey,
> var hide = true; for ( var i = 0; i < breps.length; ++i ) { var edges = breps.item(i).getEdges();>
The script you show above must not be the full script - it looks like you've only got the front part of it. That script code you have there just loops over things but does not perform any actions, that's why it doesn't work.
Try Marco's script above, or look more closely at where you got the original script because you didn't get all of it.
Show messages:  1-19  20-39  40-50
