cruise ship hulk
 1-11  12-31  32-44
6054.12
thanks all for your tips! (almost all)
Usually I'm modelling in C4D and can handle well all kind of shapes normally!
But I never built a ship-hull and without having exact blueprints
the tricky part for me is to get a "clean" surface in the area, where the curvature/bend
starts from the straight side to the nose. This bend is along a diagonal line and
always looks inaccurate.
I have a reference which I have to rebuild as exact as possible, but only from the side view.
I'll keep on trying!
thanks
Mike
6054.13
These may help: (found on net - searched for "Holland America Ossterdam Deck Plans")
Not sure their in proportion or even of the same ship...
Oooh, a good side view:
6054.14
Hull - 5 Minutes work)
Have no blueprints, just made it to show you the mehtod.
If you are not going to build real ship from this model, but made it for render or 3D printing this method for you)!
Loft (loose, exact)
Project:
https://docs.google.com/file/d/0B9EKfPF6omtHTEtrd19wYjZQTjA/edit?usp=sharing
Portfolio: www.samardac.tumblr.com
EDITED: 24 Jul 2013 by ANDREI SAMARDAC
Cool!
Lofting in the sea!
In French "lofer" is to luff on the waves! :)
6054.16 In reply to 6054.15
Pilou, cool analogy :))
6054.17
Hi Andrei,
cool! Thanks very much!
I tried all the time with loft-curves in the other direction (from rear to front)
Maybe that made me such troubles. Your workflow seams to produce
smoother results in that bulge areas.
thanks
MIke
6054.18
Hi Mike,
thanks for the images!
I got deck-plans for my ship, but they don't cover
the ship hull entirely like in your example (only to the middle of the hull)
They are helpfull for the building, but not for the hull.
thanks!
MIke
For the Vista class cruise ships, of which there are about 17, searching google for "(sister ship names) dry dock photos,"
brings up some nice pictures of the bow, a few of the stern, some aerials, and scads of interiors.
The bulbous thing on the bow, bow thrusters, and stern are impressive.
6054.20 In reply to 6054.17
Mike, no problem)
6054.21
Very cool Andrei...I really like your method and it provides a whole new dimension to MOI (especially if Michael adds the loft to point).
One question....Do you use the normal or loose option in your loft method?
Thanks!
6054.22 In reply to 6054.21
Niko, Thanx)
I use only - Loose. Normal will not able to get this Sub-D like deformations.
Also use Exact. For example this hull was modeled with Exact. Other function do not work good in different cases.
Michael is going to add loft to point, it will good upgrade.
I have some thoughts on how to make loft more advanced or may be make alternative version of MOI -Freestyle, where Loft will be on the first place, like push/pull in Sketch Up. It will have less commands and cost cheaper. But Michael works one and it's hard for him to lead 2 projects.
Also I'm afraid that Michael is not very interested in this not precise method. He concentrates more on CAD type modeling tools.
But I think there is a lot of users from Art department where precision is not so critical and they will be glad to use moi for their needs. With it's ability to export different polygonal cage it can be very useful for game creating assets especially in hard surface.
Any way, MOI now has all tools that is absolutely enough for me. And all that I said above is just thoughts that may be not very good:))
6054.23
me again - sorry!
The Modelling method works very well and I got the hull shape quite well.
But another problem occures now:
When trying to trimm the windows, some are working well,
but with others, the hull-shape gets broken.
What I'm doing wrong here?
Window path is the same like the ones which worked.
thanks again!
Mike
6054.24 In reply to 6054.23
Hi Mike, you can get weird looking "leaky trims" like that if the trimming boundaries have little self-intersecting loops in them.
It would help to see what's going on in your particular case if you could post a 3DM model file with the particular surface and cutting curve that is causing you problems with trim, it's much easier to give feedback about a problem when being able to look at the actual geometry instead of only a screenshot.
Is it possible that the cutting curve is not entirely on the surface? If it's some kidn of warped 3D curve that is not actually on the surface that can make for some difficulties with Trim. It's usually best to trim with a 2D profile curve instead of a warped 3D one. Trim will automatically project 2D cutting curve so you don't need to do any separate step of trying to get the trim curves to follow the surface manually if that's what you've been trying to do.
But again if you can post a 3DM model file that makes it a lot easier to see what in particular is going on, there are potentially many different kinds of things that can be problematic, like if you had any little loops or overshoots in the trim curves or if they were not actually closed curves that could cause generally similar looking problems.
6054.25
sorry I cannot post that file cause its confidential.
The shape I trimmed is a 2d curve which projects in front of the hull model.
The other curves (like Image 1) are exactly the same and worked well.
So I think its, what you mentioned, the little loops problem.
But how can I check this?
Or how can I solve this?
thanks
MIke
6054.26 In reply to 6054.25
Hi Mike, unfortunately it's really difficult to help you very effectively without seeing your objects. You don't need to post an entire model, just the one surface that you are trimming and the one cutting curve would do.
If you want to keep it confidential you can e-mail them to me at moi@moi3d.com.
If you can't send anything at all, then the main thing you'd want to do is closely examine the cutting curve, zoom in to them very closely and look for anomalies. Turn on control points and pull them around and look at how it deforms, if there is any "back tracking" with the curve coming back over itself (which makes it self intersecting). Look at the object type indicator in the upper right corner of the window when the curve is selected, does it read "Closed crv" or just plain "crv". Try squishing it down in the top or side view and see if it gets a "flat" snap or not - if it does not then it's not actually planar. Those are some of the various things I would do myself to investigate the cutting curve to see if it is well formed or not. There are possibly some other kinds of diagnostic methods that I'm not thinking of right now off the top of my head, it's much more normal for someone to post the geometry to get help and then I examine the geometry closely.
Also it's pretty rare but occasionally some kinds of display problems are actually just bugs in the display mechanism itself and not problems with the geometry. One way to test for that is to do a test export to a polygon mesh format like OBJ and see if it looks different in the export mesher than it does in the modeling display.
6054.27
oh, when I use "boole mix" instead of trimm
it works!
regards
MIke
6054.28 In reply to 6054.25
Hi Mike, and for this part:
If the cutting curve has a self-intersecting loop in it you need to repair or redraw the curve before you'll be able to use it as a cutting object.
6054.29 In reply to 6054.27
Hi Mike,
> it works!
If you do indeed have a self-intersecting curve in some cases the weird leaking effect can be contained in a very small area and be hard to notice right away.
If that happens it can possibly come back to bite you later on.
Again, it's hard to know exactly what you're seeing without being able to examine the geometry...
6054.30
mike,
If it's sounds complicated for you to make what Michael suggest, try to extrude those curve without caps to intersect hull, and then use trim or Boolean difference.
Anyway 3dm file would be very useful. You can remove all stuff except hull and that curve and sent it to Michael)
6054.31
Hi Everyone,
I was wondering if I could ask for your feedback and comments, regarding a cruise ship design project.
I am working on developing a cruise ship concept model through an appropriate software package (I have explored Tribon and AVEVA, though need new current licenses for these).
Its for a large cruise ship, greater than 350 m in length (on the order of Allure of the Seas in terms of facilities and accommodation, for 1100 large cabins).
I want to be able to produce enough detail useful enough for a shipyard to provide cost estimation, based on a package of provisional GAs and specifications.
However I am seeking a way to do this through a pre-built CAD based cruise ship model that could be modified, in terms of length, beam, excetera, to be able to create such a provisional shipyard package, with the expectation I could have a proper naval architecture job subsequently completed, from the ground up, to produce a drawing package that is ready for fabrication.
I would need to find a source for this CAD cruise ship model, and a method to accomplish this provisional package work with the model, and have a Naval Architect check and sign off on it.
For example, there is a cruise model in .dae format, at:
https://grabcad.com/library/cruise-ship-designed-in-google-sketchup-1
The specifications of the cruise ship are not clear, and I am trying to clarify on this. However, it appears to be a cruise ship model similar to the requirements I seek, and which could be potentially modified to meet the requirements of the concept model which needs to be created. Could I ask you for your opinion on this ? Perhaps convert it to an .iges model ? Maybe, it could be lengthened, and built further upon ?
I was trying explore how one could take this model in .dae, and convert it into a useful format.
I was wondering if you would be able to provide any useful information or guidance on how I could accomplish this.
I am up against the wall…lol… I am hoping you can help me with any suggestions.
I will look very forward to hearing from anyone knowledgeable here, and thank you very much for any few minutes you could spare me.
Kind Regards, Respectfully,
Dan
Show messages:  1-11  12-31  32-44
