nurbs to obj
 1-5  6-25  26-45  46-56
6040.46 In reply to 6040.45
Yep 3D-coat is the more classic Zbrush like ;) East against West ;) (again coded by one person Ofer Alon creator of Pixologic the Zbrush team )
I am haapy few of it because I made some French things ;)
Like this last Version of Zbrush (with the ZRemesher!
63 pages of the last manual for example ;)
http://guideszbrush.weebly.com/
I know also Andrew, a cool guy, because I have made the French version of 3D-Coat! ;)
If you go there you will see my avatar! And of course new features of the V4... but in French! :D
http://3d-coat.com/forum/index.php?showtopic=14535
EDITED: 24 Jul 2013 by PILOU
6040.47 In reply to 6040.46
I like 3D coat much more than Zbrush. Zbrush for me is some kind of extraterestrial interface... I don know what they smoke whem made this crazy stuff)) Those conception with tools and documents and files.. Or that useless 2,5 D always confuse me..... And it's strange how it becomes so popular, may be good PR. 3D coat more like russiun AK-47, simple and realible. I tried 3D Coat and it is so simple and fun. Great soft)
Nica avatar Pilou))) As I can se you are some kinf of french magik wand for CG Developers))
EDITED: 24 Jul 2013 by ANDREI SAMARDAC
6040.48
First test with 3D coat. Spent all day trying to understand how it works... And finally get good result)
Tried to make low polly model with normal map.
And this is workflow:
Image Hosted by ImageShack.us
Export High Res
Export Low Res
Result 94 triangles, 100 quads.
6040.49
And another test:
188 triangles, 144 quads.
Now thinking about the way how to work,for now it's clear you have to have 2 model one with fillet and one without.
6040.50 In reply to 6040.48
Great looking result in only 194 polys!
Another thing you can experiement with is turning "centroid triangulation" off - you have to do that under moi.ini by setting:
[Mesh Export]
CentroidTriangulation=n
When it's turned on it will generate triangles when possible by connecting the centroid point of an n-gon to its outer boundarys, that gives a kind of X like looking pattern in some areas. It can help to reduce skinny triangles but also increases vertex count by adding in that additional central point.
If you turn it off then those central points will not be added and n-gons will get triangulated only by connecting their outer boundary points, that might be better for you.
6040.51 In reply to 6040.50
Thanx)
Just tried this thing and can not understand clearly the differences.
Could you pleas make some screen or draw the simple cage, to understand how it works.
6040.52 In reply to 6040.51
This is what i descoverd.
The differences.
centroid OFF - 473 Poly
centroid ON - 491 Poly
Michael what us the main advantage of making centroid off?
It looks better with off.
EDITED: 25 Jul 2013 by ANDREI SAMARDAC
6040.53 In reply to 6040.52
Hi Andrei, on your example you can see the differences pretty clearly on the large planar face, notice how with centroid triangulation, the triangulation of that big n-gon takes on a radial structure with an internal point added like this:
Without centroid triangulation, it intead forms triangles by only connecting vertices on the outer n-gon boundary and not generating any extra internal central point, which gives you this instead:
On other areas the difference looks more like this:
Which one is better depends on your particular needs - when it's on it can help make some triangle structures sort of more regular and symmetrical like the big face in this example, and in some cases makes triangles that are kind of more wedge shaped and don't stretch quite as far across a space. But also because it adds an additional internal point it produces a higher polygon count and sometimes having the radial structure in small areas looks kind of strange.
For a while now I've had the default changed to have it off by default but for a long time before that it was on by default.
If you want to fully minimize polygon count you will probably want to turn it off.
If you like the radial structure of the large face shown above and don't mind some additional vertices being added then turn it on instead.
6040.54 In reply to 6040.53
Yep thank you I understand. And I like more geometry with non collapsed style)
Also today I try this and looks like circle extrusion it still collapse n-gone.
Uploaded with ImageShack.us
Portfolio: www.samardac.tumblr.com
6040.55 In reply to 6040.54
It will still use centroid triangulation on n-gons that have all vertices at equal distances from the centroid point, so basically only totally regular polygons like the cylinder cap.
The centroid setting actually controls whether centroid triangulation is also used on other kinds of non-regular polygons where it is possible to make a valid triangulation by connecting to a centroid point.
6040.56 In reply to 6040.55
Good, it's not problem for me just noticed it.
Show messages:  1-5  6-25  26-45  46-56
