Power of LOFT!
 1-7  8-27  28-47  48-62
6037.48 In reply to 6037.45
Thanx BurrMan,
Really good command, I think I'll use it, did not know about it, thank you very much!
Portfolio: www.samardac.tumblr.com
6037.49 In reply to 6037.47
Hi Andrei,
> Very complicated, I think it's very low level for me.
As I've mentioned many times before, really if you want to do direct surface point modification a sub-d modeling toolset tends to be a better fit for that than NURBS modeling.
Some of the things that give accuracy to NURBS modeling do not lend themselves well to squishing surfaces around. Some problems like internal segmentation on circles/arcs/spheres can be avoided though by doing a rebuild on it.
6037.50
Hello,
Interestingly this is a very good illustration why you wouldn't use loft (left) as a replacement for a more appropriate tool for the task, revolve (right). Same set of curves, just ran the commands. A curvature analysis is shown in the picture. Poor surface quality in the lofted shape which could lead to further problems as it is modified. No such problems with the revolved shape.
Loft and Revolve
EDITED: 2 Feb 2025 by OSTEXO
@Andreï
As fan of Loft maybe this script can interest you ;)
http://moiscript.weebly.com/deacuteplacer-des-objets.html
link of script is on top page! MoveSlicetoPoint
Interesting when you have a lot of slices
EDITED: 21 Jul 2013 by PILOU
6037.52 In reply to 6037.51
Thank you Pilou, intersting script, looks like I'll use it.
Message 6037.53 deleted 2 Aug 2013 by ANDREI SAMARDAC
6037.54
Michael.
While using the Loose option in the Loft tool I wondered if a slider control would be a worthy addition to let the degree of 'looseness' be tweaked to one's liking?
Martin.
6037.55 In reply to 6037.54
Hi Martin,
It would be great, but unfortunately I don't know how I'd implement it - the internal details of how loose loft works does not really involve any sort of looseness factor in how it functions. Usually an adjustable slider control for things like that can work when there is some kind of scale factor involved in the calculations, but when there's nothing resembling that kind of multiplying scale factor it's then difficult to include one.
6037.56
Hi Michael.
Yeah I know that many of my ideas border on the impossible :-)
Thanks for taking the time to reply.
Martin.
6037.57 In reply to 6037.54
Martin,
you can use this method.
1. Use loft (normal mode) to build a surface; Draw a circle.
2. Select the circle; Array -> Dir;
3. Select the circles -> Loft (caps off) -> Flow tool. Use cylinder as base surface.
4. Now you've got more curves, so you can variate the power of loft by selecting and deselecting those curves.
This method works good with any curves. I could write a script, but, unfortunately, I haven't free time for it now.
EDITED: 7 Mar 2022 by SMIRNOV
6037.58 In reply to 6037.57
Project simple Lines don't give the same result ?
6037.59 In reply to 6037.58
Your method works if all curves parallel to each other.
OK, how about this one? :)
6037.60
Hi Max and Frenchy.
Thanks for these techniques of refining the loft surface, I wouldn't have thought of either of them!
All the best.
Martin.
6037.61 In reply to 6037.59
Maybe Iso Lines ?
but your methode is surely more versatile!
6037.62 In reply to 6037.61
Great idea!
My method is more accurate and can be automated, but Iso Lines method is more faster and easier.
It will be enough in most cases. Thank you.
Show messages:  1-7  8-27  28-47  48-62
