Power of LOFT!
 1-19  20-39  40-59  60-62
6037.40 In reply to 6037.38
Works fine for me! With any options!
Here not closed but works fine also closed!
remember this ;)
6037.41 In reply to 6037.38
Hi Andrei, it seems to be working fine there - maybe the thing you weren't expecting is that it works on a per-segment basis, so for instance if you put in # Points mode and give that 10 points, it will be 10 sample points used for every segment of the loft, like the arc piece, line pieces, etc... Also the min number of points is 4 if you try to put in less than 4 per segment it will still use 4 instead.
If you would like for the loft to be treated as one single surface rather than as a segmented one, run Rebuild on the curves before doing the loft so that the curves are only single segment curves instead of made up of multiple segments.
Does that explain what you're seeing?
6037.42 In reply to 6037.39
> Does it possible to have as option something who write the functions,
> ShortCuts, Mouseclicks... used in a corner of the screen?
I think that some types of screen capture software can do that for you, for example Camtasia can make a red circle appear around the mouse when clicks happen and it's also possible to make labels show for keyboard shortcuts that are used, here is a demo video on how to do that: http://www.screencast.com/t/Sz0jxaa6
So it's probably not something that I'd try to do directly in MoI since a good screen capture program can already handle it...
6037.43 In reply to 6037.41
Yep michael I understand this concept per segment, I noticed before that after rebuild it work, now everything is clear!
But tell me pleas conception about exact in this case. I see it not produce exact amount of points.
Pilou, I mean Points and Exact dose not work) Loft work good)
Red rocket)))
6037.44 In reply to 6037.42
Michael,
>I think that some types of screen capture software can do that for you.
I think it will not say more to people what shortcuts I use. I think Pilou wanted so see commands?
Pilou if you want to see my shortcuts you can find them here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5948.1
6037.45 In reply to 6037.44
Hey Andrei,
I think you would get a kick out of the cross section command if you havnt discovered that yet. You can find it and get info here:
http://kyticka.webzdarma.cz/3d/moi/#CrossSection
Burr
6037.46 In reply to 6037.43
Hi Andrei - "Exact" does not so much actually mean "exact number of points" - it means "exact shapes". In exact mode profiles are made compatible with one another by knot insertion so that the shape of the loft surface will go exactly through each profile but the end surface inherits the combinations of all point and knot structures of every curve, so usually the final surface will have more points on it than every input curve.
If all the curves are exact copies of one another then they should merge together easily though and you do get the same number of points in the surface in that case.
But because the loft is internally generated as a single big surface before it's split at creases, all pieces of the loft will get "degree elevated" to the highest degree segment, so in this case the arc is degree 2 so the linear areas get degree elevated to degree 2 as well and that's why they have an additional point in those areas.
Also in addition to that when you turn on control points for arc or circle curves what you actually see are not the control points of the exact arc or circle but instead the control points of a rebuilt version of the arc or circle, that's because an exact NURBS circle or arc is itself made up of quadrants that do not deform very well by control point manipulation, so if you edit an arc's control point it automatically switches it into a smooth rebuilt version of it so that it doesn't kind of split apart into 2 arcs divided by some internal point. But in the generated sphere surface you're seeing the direct surface control points in that case. If you pull some of those sphere fragment control points around you'll see some of the splitting apart that I'm referring to, that happens when a surface or a curve has a "fully multiple knot" in it, it sort of means the curve or surface has another kind of internal segmentation in it.
Hope this helps explain some of the additional details.
6037.47 In reply to 6037.46
Very complicated, I think it's very low level for me. One thing I understand is - If all the curves are exact copies of one another then they should merge together easily though and you do get the same number of points in the surface in that case. In all other ways exact does not mean exact amount of points)) And understand a bit about circles)))
Thanx)
6037.48 In reply to 6037.45
Thanx BurrMan,
Really good command, I think I'll use it, did not know about it, thank you very much!
Portfolio: www.samardac.tumblr.com
6037.49 In reply to 6037.47
Hi Andrei,
As I've mentioned many times before, really if you want to do direct surface point modification a sub-d modeling toolset tends to be a better fit for that than NURBS modeling.
Some of the things that give accuracy to NURBS modeling do not lend themselves well to squishing surfaces around. Some problems like internal segmentation on circles/arcs/spheres can be avoided though by doing a rebuild on it.
6037.50
Hello,
Interestingly this is a very good illustration why you wouldn't use loft (left) as a replacement for a more appropriate tool for the task, revolve (right). Same set of curves, just ran the commands. A curvature analysis is shown in the picture. Poor surface quality in the lofted shape which could lead to further problems as it is modified. No such problems with the revolved shape.
Loft and Revolve
EDITED: 2 Feb 2025 by OSTEXO
@Andreï
As fan of Loft maybe this script can interest you ;)
http://moiscript.weebly.com/deacuteplacer-des-objets.html
link of script is on top page! MoveSlicetoPoint
Interesting when you have a lot of slices
EDITED: 21 Jul 2013 by PILOU
6037.52 In reply to 6037.51
Thank you Pilou, intersting script, looks like I'll use it.
Message 6037.53 deleted 2 Aug 2013 by ANDREI SAMARDAC
6037.54
Michael.
While using the Loose option in the Loft tool I wondered if a slider control would be a worthy addition to let the degree of 'looseness' be tweaked to one's liking?
Martin.
6037.55 In reply to 6037.54
Hi Martin,
It would be great, but unfortunately I don't know how I'd implement it - the internal details of how loose loft works does not really involve any sort of looseness factor in how it functions. Usually an adjustable slider control for things like that can work when there is some kind of scale factor involved in the calculations, but when there's nothing resembling that kind of multiplying scale factor it's then difficult to include one.
6037.56
Hi Michael.
Yeah I know that many of my ideas border on the impossible :-)
Thanks for taking the time to reply.
Martin.
6037.57 In reply to 6037.54
Martin,
you can use this method.
1. Use loft (normal mode) to build a surface; Draw a circle.
2. Select the circle; Array -> Dir;
3. Select the circles -> Loft (caps off) -> Flow tool. Use cylinder as base surface.
4. Now you've got more curves, so you can variate the power of loft by selecting and deselecting those curves.
This method works good with any curves. I could write a script, but, unfortunately, I haven't free time for it now.
EDITED: 7 Mar 2022 by SMIRNOV
6037.58 In reply to 6037.57
Project simple Lines don't give the same result ?
6037.59 In reply to 6037.58
Your method works if all curves parallel to each other.
OK, how about this one? :)
Show messages:  1-19  20-39  40-59  60-62
