Power of LOFT!
 1-3  4-23  24-43  44-62
6037.24
Hello,
Having a variety of tools in MoI really becomes important when it comes to precision and surfacing operations. I try to use the commands that will give me the best ability to easily and precisely modify the solid when the surfaces are tweaked and revised. I would not use loft for some operations for the simple reason that using loft makes a mess of the control points and desired modification becomes very difficult if not impossible. I'm not close to being highly qualified in understanding the nuances of surfacing, but I know enough to realize that thought needs to be put into what tools will give you the best final and easily modifiable result.
6037.25 In reply to 6037.20
My 2 cents
Most of my work is geometric architecture. The basic tools like extrude and revolve handle 95% of my needs.
While I recognize the value of LOFT and use it now and then, I would not want to give up the more basic and faster tools.
cheers,
eric
6037.26 In reply to 6037.24
OSTexo
It's because you use Loft style - Normal and Profiles - Auto. With - Loose, Exact you will have the same amount of points as extrude have, and a lot less then sweep or network. And any modification is very simple.
6037.27 In reply to 6037.20
M-dynamics if I understood right it loft from curves to point. If it so it is good option)
6037.28
Hello,
I guess it depends on the model you're trying to build and the surface quality you're trying to achieve. Both number and the position of control points play into it. I guess the pure loft method is OK for blobby models that do not have to fit any particular constraints but that might miss an important point of having a tool like MoI, where you are able to use a variety of equally beneficial tools to achieve both a precise and easily modifiable result. I can see using Loft only how you can quickly get into a very bad spot where you are unable to change one area of a model without changing another area that you wanted to keep untouched. I know this through my own experience, and have discovered and been helped to find different ways to achieve a more desirable result with a variety of tools.
6037.29 In reply to 6037.3
Extrude in this case is very fast
You do not need to boolean out the holes as you can just grab all the shape and text profiles and extrude straight up or down
the holes are formed automatically from the solid
This was for the beginning of the thread with the 5 sided extrude that Michael did
shayne
6037.30 In reply to 6037.18
Very good idea with the "loft to point"!
6037.31
The tools that have to be used come from the thinking process you have in mind to achieve the result in the cleanest (and most correct) way possible.
6037.32
6037.33 In reply to 6037.32
M-dynamics, good example, thanx)
Michael, it would be good to have "loft to point" in MOI.
Portfolio: www.samardac.tumblr.com
6037.34
Hay Micahel, new method to to make revolve with loft! Revolve - 15 sec, Loft - 15 sec!! )))))
EDITED: 20 Jul 2013 by ANDREI SAMARDAC
6037.35 In reply to 6037.34
Hi Andrei,
Yup, actually that's the method that I had thought you were talking about originally, remember my previous post here? :
http://moi3d.com/forum/index.php?webtag=MOI&msg=6037.10
The main problem with that method is again accuracy - the revolve generates a shape that is 100% exactly a sphere in the top part where you have an arc profile.
The loft through different angled stations only approximates a sphere to some unspecific tolerance level, it's not an exact sphere shape.
It's important for some people's uses of MoI to have accuracy in what they generate.
The easiest way to generate an exact revolved shape that is 100% round and exactly matches one specific profile curve is to use Revolve to do it.
You also get a different kind of history updating when you use a loft through many profiles like you show there - the revolve lets you edit a single profile and the revolve will update as you tweak it, giving you a new exact revolve every time just from having drawn one single curve.
It just tends to be good in general to use the smallest number of curves to generate things, like in this case using only one profile curve and using revolve is just the most efficient way to do it, it only uses one curve. Being able to generate large amounts of your model from a small number of curves is basically the key thing that makes NURBS modeling powerful for mechanical shape design and different from sub-d modeling.
For Loft in addition to replicating the curves you also have to set the "Closed" option which is not on by default. And again, needing to use some sequence of steps and special options to generate a really basic shape like this is a barrier for someone who is learning MoI to be able to create a simple shape like this...
6037.36 In reply to 6037.35
I know Michael, you are right I do not pretend to replace revolve with loft)
Just got and idea about this method, and yes you show this method before I forget it)
I just fun of Loft you know))) One question why when normal styly selected, Exact and Point do not work?
6037.37 In reply to 6037.36
Hi Andrei,
They work fine for me over here... If you have an example where they don't work can you please post the 3DM file for it so I can take a look?
6037.38 In reply to 6037.37
This one.
Just an idea :)
Does it possible to have as option something who write the functions, ShortCuts, Mouseclicks... used in a corner of the screen?
Because in the last Video of Samardac, that was be useful when you replay in slowtime! ;)
EDITED: 20 Jul 2013 by PILOU
6037.40 In reply to 6037.38
Works fine for me! With any options!
Here not closed but works fine also closed!
remember this ;)
6037.41 In reply to 6037.38
Hi Andrei, it seems to be working fine there - maybe the thing you weren't expecting is that it works on a per-segment basis, so for instance if you put in # Points mode and give that 10 points, it will be 10 sample points used for every segment of the loft, like the arc piece, line pieces, etc... Also the min number of points is 4 if you try to put in less than 4 per segment it will still use 4 instead.
If you would like for the loft to be treated as one single surface rather than as a segmented one, run Rebuild on the curves before doing the loft so that the curves are only single segment curves instead of made up of multiple segments.
Does that explain what you're seeing?
6037.42 In reply to 6037.39
I think that some types of screen capture software can do that for you, for example Camtasia can make a red circle appear around the mouse when clicks happen and it's also possible to make labels show for keyboard shortcuts that are used, here is a demo video on how to do that: http://www.screencast.com/t/Sz0jxaa6
So it's probably not something that I'd try to do directly in MoI since a good screen capture program can already handle it...
6037.43 In reply to 6037.41
Yep michael I understand this concept per segment, I noticed before that after rebuild it work, now everything is clear!
But tell me pleas conception about exact in this case. I see it not produce exact amount of points.
Pilou, I mean Points and Exact dose not work) Loft work good)
Red rocket)))
Show messages:  1-3  4-23  24-43  44-62
