Plugin Dialog Box
All  1-2  3-4
6030.3 In reply to 6030.1
Hi Sharif, your split line issue is because you're actually getting 2 iframes in there, not just 1 iframe at a time.
You end up getting 2 because the script is looking for an iframe with an id of "StartFrame" (note no space in there), but your initial iframe looks like this:
		<flex_hbox id="UpperContainer">
			<iframe id="Start Frame" class="flex"></iframe>
		</flex_hbox>
Take a close look at the id="" attribute that you currently have on that initial starting iframe, note that it has an extra space added into it - that makes a mismatch between what the script is looking for.
Remove that space from the id="" attribute so you just have:
                        <iframe id="StartFrame" class="flex"></iframe>
And that should fix up that problem.
6030.4 In reply to 6030.3
Hi Michael;
Thank you! for your quick reply. It works perfectly now.
-sharif
Show messages: All  1-2  3-4
