cannot open V3 beta
All  1-3  4-6
6022.4 In reply to 6022.2
you got it right.
I did change date / time.
I have installed some microsoft programs during week end and some how now my laptop is messed up.
I did a system restore and speed is back to normal, but when I change back to updated date/time, everything is slowing down again.
right now, I am using todays' date but of 1 year ago now to see how long it will be OK without slowing down.
If still does that on this system restore "wrong" date, then might be overheating.
Anyway if you can forward me that utility would be great.
Of course I can open files on MOI v2, but still I am used to V3 beta now.....
my email is
rudy61_at_ iowatelecom.net
Thanks very much.
Rudy
6022.5 In reply to 6022.4
Hi Rudy, I'll send you the utility but you shouldn't use it until you're all done switching your clock around and can leave it set to the current date. You can't really run the v3 beta properly without the date set correctly and if you're changing the date back and forth a lot you'll just run into the same problem again, and also the beta reset utility will only work one time so you'll want to be finished doing clock stuff when you use it.
6022.6 In reply to 6022.4
Thank you Michael,
got it.
Rudy
Show messages: All  1-3  4-6
