The Little Professor
All  1  2-4
6015.2 In reply to 6015.1
Hi Paul, that's some great work, a lot of nice motion and feel in a short time!
Re: embed - to embed the video to play from directly inside your post, click the "Share" button in the upper right corner of the video, that will then pop up a box that has a chunk of text labeled "Embed" on it - click on that text and it will select, you can then use Ctrl+C to copy it and then just Ctrl+V paste that HTML code directly into your forum message and that will embed the video in your message like this:
The Little Professor - Redshift render test from Paul Griswold on Vimeo.
6015.3
Hi Paul,
That's a very good looking result!
If you don't mind saying, what was your output resolution and render time per frame
with Redshift?
6015.4 In reply to 6015.3
I rendered at 1080p. The background & the calculator were separate passes. I don't honestly remember what the render times were. The calculator up close was really slow, though, because it's refractive, reflective, has motion blur and depth-of-field turned on. I think those frames were around 2 minutes per frame. Once it's in the frame entirely, it probably was maybe 15-30 seconds a frame.
Thanks!
Paul
Show messages: All  1  2-4
