Another fiilet question
All  1-5  6-19
6008.6 In reply to 6008.1
I think part of the problem is that your outer radius / circular scallop feature is not tangent with the inner radius / scallop feature.
I created, in your file, a similar profile and with a single click, put a fillet of 2 units on the whole thing just by clicking one edge. Since I made my initial sketch with tangent relationships the fillet was able to 'chain' around all the edges in one shot.
If you look at your object from the top view and zoom in close to where the outer and inner radii meet you can see that the outer rounded surface runs out just past the point of tangency while the inner radii comes up short of being tangent. What you will need to do is either make the outer radii the driver and adjust the inner radius to meet tangent, adjust the inner radii as the drive and make the outer radius match tangent or split the difference.
The image attached shows you in black lines, how your profile sketches cannot be tangent....ever. While the red line for the inner radii shows how you can use the outer radius as the driver while changing the inner radius in order to run tangent as it should be.
This isn't a MoI or other program issue but just modeling practice. I have had my knees skinned a few times too but best to learn as soon as possible.
Size: 155.4 KB, Downloaded: 52 times, Dimensions: 1058x578px
6008.7 In reply to 6008.6
Very helpful, thank you!
I tend to create my extrusion shapes by boolean'ing together a series of 2D shapes first so I guess I need to pay more careful attention to how those shapes connect up with each other. Definitely a learning curve here and I appreciate the help! NURBs modeling isn't something I do every day...
6008.8 In reply to 6008.7
Nice, so through building with a different mindset I was able to get it to fillet. Looks awesome in 3DSMax too.
OK, so I just need to come to grips with NURBs modeling then. Gotta make room for yet another workflow in my tiny brain. :)
Thanks all!
6008.9 In reply to 6008.8
Nice work.
6008.10 In reply to 6008.7
Yes the vertical one can permit to fill all the Curves in the same time! Of course with a very little fillet!
But of course that makes a fillet also on the vertical one! :)
But as said previous your curves were not well reccorded! :)
EDITED: 4 Jul 2013 by PILOU
6008.11 In reply to 6008.5
Hi Warren, it sounds like you've got this figured out now, but just in case:
> I guess the problem lies in how I created the outer scallop shape in the first place then?
> That vertical line seems to be the fun killer. Is there a way to remove it or does it all come
> down to how I create things in the first place?
The vertical line is a problem because the surfaces on either side of it are not smooth to one another, they come to about a 15 degree angle and these kinds of shallow angles where things are sort of close to being smooth but not quite actually smooth tends to make things difficult for filleting.
It isn't necessary to totally remove those vertical lines, but what you want is for the surfaces on either side of it to be tangent to one another rather than only slightly creased to one another.
> Basically, get the first steps right or it's never going to work?
Yeah it helps avoid a lot of problems if your original curves that were extruded were tangent to one another.
For filleting it's usually best if things meet at a sharp angle to one another or are smooth where they meet. Things that are just kind of close to being smooth but not actually smooth (like say 5 or 10 or even 15 degrees off like in your case here) make things a lot more difficult for the filleting mechanism. That's because anytime you have pieces meeting sharply to one another at all the fillet segments that follow them will not line up directly to one another and will need to be trimmed or have corner juncture pieces put in place, and when things at at shallow angle the various calculations that go into that become more difficult.
6008.12 In reply to 6008.5
Hi Warren,
> Is the general idea in MoI "large sweeping actions" rather than "small, cumulative actions"?
It kind of depends on the particular circumstance. But it can make things easier for filleting if you have larger pieces because a single large non-segmented curve or large surface piece will be all smooth inside of it. So that can tend to avoid ending up with things meeting up at some slight shallow angle.
Slight shallow angles between pieces will tend to cause problems with filleting.
" ... I tend to create my extrusion shapes by boolean'ing together a series of 2D shapes first"
I've had good luck building smooth 2D profile closed curves by drawing the critical segments first, then use Blends to bridge the gaps. That is, use Blend to create the radius transitions to complete the closed curve.
This has given me no problems when it comes time to extrude and fillet the resulting solid.
Perhaps Michael can chime in and explain if a Blend on two line segments will always be tangent where they join.
I may be drawing curves in a more complex way than necessary, but I find Blend works well for 2D drawings.
Click image to enlarge.
Ed
EDITED: 4 Jul 2013 by EDDYF
Size: 108 KB, Downloaded: 66 times, Dimensions: 400x369px
6008.14 In reply to 6008.13
A great way of creating tangent relationships.
6008.15 In reply to 6008.13
HI ed,
Yup, a blend between 2 line segments will be tangent to each line segment.
Does this the same in the 3D Space when curves are and come from anywhere orientation ?
I suppose yes but ...
EDITED: 5 Jul 2013 by PILOU
6008.17 In reply to 6008.16
Yes, the blend will still be tangent to each curve even if the curves are not in the same plane.
The blend part itself will not be flat in cases like that, it will bank around to meet up with the curves.
6008.18 In reply to 6008.17
Thx now I am sure! :)
6008.19 In reply to 6008.14
Nice! That's really helpful, thanks for the Blend tip.
Show messages: All  1-5  6-19
