A quick (and dirty) Script Palette script
 1  2-21  22-41  42-44
Perfect : I had not enabled the French Language! :)
So when I enable it magically "Fermer" appears as aspected!
Sorry for the little disturb!
Of course I had also the red x button! ;)
EDITED: 6 Feb 2014 by PILOU
5993.23 In reply to 5993.22
> Perfect : I had not enable the French Language! :)
Mystery solved! :)
5993.24
Why I can not to have this script correctly shown in window?
script: /*! Show all except curves, points and Hidden style*/ var obj = moi.geometryDatabase.getObjects().getBReps(), st = moi.geometryDatabase.findstyle("Hidden",0), sti; if (st) {sti = st.index;} else { sti = "nf";} for ( var o = 0; o < obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};
In script window it looks like this:
< obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};"> Show all except curves, points and Hidden style
Looks like it becouse <.
5993.25 In reply to 5993.1
Is it any way to make some categories in this script window, to store scripts more logically?
5993.26 In reply to 5993.24
Hi Andrei,
The problem is caused by the double quotes around "Hidden" and "nf" in the script.
If you replace the double quotes with single quotes it should work fine:
script: /*! Show all except curves, points and Hidden style*/ var obj = moi.geometryDatabase.getObjects().getBReps(), st = moi.geometryDatabase.findstyle('Hidden',0), sti; if (st) {sti = st.index;} else { sti = 'nf';} for ( var o = 0; o < obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};
This is a limitation of the way the script palette works.
Dinos
5993.27 In reply to 5993.26
dinos, thank you.
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
Works fine for the "one line" but for the "commands" I see well the name of the Line of the Command but
A little problem!
Of course the command works when I make : Press TAB ...and type _vClone !
Idem if I take a direct native command like Blend!
EDITED: 14 Feb 2014 by PILOU
5993.29 In reply to 5993.28
Hi Frenhcy,
you have to leave a space between the command and the comment:
Blend /*!Blendo*/
Otherwise my script and/or Moi get confused.
Dinos
5993.30 In reply to 5993.29
aaaaaaaaaaaaaaaaaaaaaaaaaaaaah!!!!!!!!!!!!!!
All is fine now! Bravo!
5993.31
Hi dino!
You use this sign "!" to pick the commands for your palette. In your script I have seen some of this sign.
Can i change this signs for example in to "?" or other?
Then copy and rename your script "Script Palette 2" to make different category of caommands.
I am not a programmer. May be this is a way.
Thanks for your work!!
Hopefully, Hans
5993.32 In reply to 5993.31
Hi Hans!
I havent tried it, but yes it should work as you describe.
Just change the ! at line 22 in the second copy of the script to something else:
title = line.match(/\/\*\!(.+)\*\//);
Its escaped so you should be fine with most symbols.
I wrote this script primarily for me, and released it in case someone else needed a relatively simple way to keep their scripts in a palette. The Shortcut Keys panel inside Options is hardcoded and cannot be altered so i used the ! sign to emulate a check box next to each command. In my mind the ! sign is actually a check box saying "include in the palette" ;-)
I could replace the ! with !1, !2 etc for multiple categories, but there a few issues that i'll have to think about such as naming the categories, passing parameters to the script etc.
If i can find some free time i might give it a shot.
In the meantime what you are describing is the best way to do it.
Dinos
Cool trick!
Excellent!
Nothing but as you can see above the button is not centered ! ;)
So does exist some code for resolve this very very very little disturb ? :)
5993.35 In reply to 5993.34
That's normal that buttons on dialogs in MoI are not centered, that's because it looks weird on larger dialogs. See for example the Close button on Options dialog. This dialog is just using the same thing.
5993.36 In reply to 5993.35
Thx for the info!
5993.37
dinos,
thank you for your adwise.
thank you for making the test.
Hans
The only default that I see is that you must create a different Shortcut for each item even you don't need it if you want just use the text palette!
use the same shortcut for different commands don't work! :(
an empty Left column don't work :(
Or does exist a little trick for avoid that ?
Curiouslly something like
Alt + 1 + 2 Cone /*?cona*/
Alt + 1 + 3 Rectangle /*? rectangla*/
Alt + 1 + 4 Lines /*?Ligna*/
...etc
Close Options Shortcut, Exit Moi
works only at the first re-launch of Moi! Cool... :)
...but not at the second re-launch! :(
And disapears from the Shortcut list!
(words following are just letters not real French words except "Tuber" = Sweep and "Fermer" = Close ! )
EDITED: 16 Feb 2014 by PILOU
5993.39
Hi Frenchy!
I had the same result.
But there are some more of "!". Replace all with "?" and the ":)" comes back.
Hans
5993.40 In reply to 5993.39
Yes but the number of possible ShorCuts are dramatically decreasing if you want keep some ones for real typing ShortCuts !
5993.41
>> And disappears from the Shortcut list!
Found another little trick:
Create copies for each category. For example one for spirals, '../ui/ScriptSpirals.htm'
Change Line 22 to utilize a different character, unique for each category, as the '?' had been suggested: title = line.match(/\/\*\?(.+)\*\//);
[Shortcut Keys]
Alt+1=script: /*!Spirals...*/ moi.ui.createDialog( 'moi://ui/ScriptSpirals.htm' );
Alt+2=_ArchimedeanSpirals_ /*?ArchimedeanSpirals*/
Alt+3=Logarithmic2D /*?Logarithmic 2D*/
Alt+4=EulerSpiralSlider /*?Euler Spiral*/
Alt+5=EulerSpiral3 /*?Euler Spiral v3*/
Alt+6=FrenetClothoid3D_RK2_v1 /*?Frenet Clothoid 3D*/Alt+DownArrow=Nudge Down Small
A=Join /*!Join*/
Alt+S=IncrementalSave /*!Incremental Save*/
Ctrl+R=ReBuild /*!ReBuild*/
Ctrl+Shift+S=ScaleArray /*!ScaleArray*/
G=SpurGearProfile /*!Spur Gear*/
z=script:moi.ui.createDialog( 'moi://ui/ScriptPalette.htm' );
This way, items from the first list can 'createDialog' for other sub-categories:
And since each category file parses the ini file separately, the process remains repeatable!!
Even though, there are still yet a finite number of key-codes available for listing.
EDITED: 25 Apr 2015 by IGNITER
Show messages:  1  2-21  22-41  42-44
