A little W.I.P
 1-6  7-26  27-46  47-66  67-68
5991.7 In reply to 5991.4
It looks terrific. I'm looking forward to seeing your progress.
Trains, and the like, are always great things to model when learning a CAD system.
_________________________
Don Cheke
Visit: Textual Creations
5991.8
Very very nice results Krass!... is it me, or does every connecting surface have a fillet?
5991.9 In reply to 5991.8
Mike K4ICY, thank you for the high appreciation of my work.
If I correctly understood your question, yes - all the mating surfaces have fillets and chamfers in accordance with factory blueprints.
Or did you mean something else?
5991.10 In reply to 5991.7
Don, thank you for your compliment! ))
You are right - Moi 3D in some cases, very close to the high-precision CAD-systems.
PS. A steam locomotive is the memory of my grandfather, who worked on such a machine.
Steam locomotive Em (0-5-0) - the most mass model in the USSR, one of the most reliable locomotives in the world.
From 1912 to 1957 was built about 11 000 of these machines.
EDITED: 2 Aug 2013 by KRASS
Size: 191.2 KB, Downloaded: 384 times, Dimensions: 1074x744px
5991.11 In reply to 5991.9
That's what I meant... and very impressive attention to detail!
Mike
5991.12 In reply to 5991.11
Mike, I just simulate accurately on the drawings.
However, when the model will be FULLY assembled, whether it "swallow" MOI-3d? )))))) Oy-oy... :)
5991.13 In reply to 5991.12
A little more of the work process.
Bumper locomotive with pull hook and Ulengut screw coupler.
EDITED: 1 Sep 2022 by KRASS
Size: 180.6 KB, Downloaded: 147 times, Dimensions: 1600x1054px
Size: 279.2 KB, Downloaded: 132 times, Dimensions: 1600x1054px
5991.14 In reply to 5991.13
Nice krass,
Did you find the "make Thread Tap" script? (Or any of the other make thread scripts)
If not, it may help you in some areas, regarding your pictures...
5991.15 In reply to 5991.13
Very nice update ... Burr is right though, those threads cut in real sharp. :)
Martin Spencer-Ford
5991.16 In reply to 5991.14
To: BurrMan
If I translated correctly Your words, we are talking about the fact that the screw threads very sharp edges. I understand?
This is still the first attempt to make a threaded connection. Unfortunately I have 2 beta and scripts for the manufacture of thread on it to work. I will look for other ways.
5991.17 In reply to 5991.15
To: TpwUK
Thanks a lot for evaluation and critique my work!
As a novice, I was important to view each specialist
5991.18 In reply to 5991.16
"""""""""If I translated correctly Your words""""""""""
It was not a critique. It was a reference to scripts made in MoI that you could use to help your process.
See this link, and the 2 links in the first post.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5489.1
5991.19 In reply to 5991.18
For: BurrMan
Thank you so much for your advice and support!
Regarding the criticism I mean that is a criticism of colleagues, observations of more experienced colleagues are always important.
About the scripts. Thanks, I'll try all that is written there.
But. I truly understand that there are 3 versions MOI of the scripts?
I have a 2nd version.
5991.20
My compliments also for first rendered images,materials are great
I suggest to bevel (1-2mm) all edges,like in reality..your render will be more real
Bravo!
M
5991.21
Even small progress in the work on model.
Added brake system.
Size: 468.9 KB, Downloaded: 126 times, Dimensions: 1920x1265px
Size: 402.4 KB, Downloaded: 78 times, Dimensions: 1920x1265px
Size: 441.4 KB, Downloaded: 113 times, Dimensions: 1920x1265px
Size: 307.7 KB, Downloaded: 125 times, Dimensions: 1920x1265px
5991.22 In reply to 5991.21
Looking awesome krass! love the detail, keep it coming.
5991.23 In reply to 5991.22
For: DannyT
Thanks for the appreciation! And drill follow a very easy - just do all the elements exactly according to the drawings. ;))
But, as we say in Russia: "the story is told, and not soon the work being done" ..:))
5991.24
So, let's continue.
Added support under the smoke chamber (the thing with large round holes)) and put in its place steam cylinders.
And with that, and the other had a lot of trouble, but it was worth it.
Already started to emerge and become clearer. ))
Size: 421.5 KB, Downloaded: 204 times, Dimensions: 1600x1054px
Size: 407.4 KB, Downloaded: 107 times, Dimensions: 1600x1054px
Size: 382.8 KB, Downloaded: 151 times, Dimensions: 1600x1054px
Size: 315.5 KB, Downloaded: 72 times, Dimensions: 1600x1054px
Size: 292.3 KB, Downloaded: 124 times, Dimensions: 1600x1054px
5991.25
Beautiful work, Krass! I am also working on a steam loco (American); and you have given me a new target in excellence to aim for!
What do you use for your renderings / lighting?
Ron
5991.26 In reply to 5991.25
Ron, thanks for a high estimation of my work!
For visualization I use Keyshot standalone render - with this program you can import models in the .3DM format
Show messages:  1-6  7-26  27-46  47-66  67-68
