A little W.I.P
 1-2  3-22  23-42  43-62  63-68
5991.43
Thank you for showing this Krass, what beautiful accurate work.
5991.44 In reply to 5991.43
Thank you all! In this forum, I found a lot of advice and work of masters from whom I am learning!
5991.45
Thus, the lower part of the locomotive is almost complete, remained a dozen parts.
He gathered all modeled in a single file.
The file weighs 288 megabytes and is already beginning to slow down MOI3D.
Although Keyshot this big file "grinds" without any problems...
EDITED: 24 May 2015 by KRASS
Size: 563 KB, Downloaded: 138 times, Dimensions: 2500x587px
5991.46 In reply to 5991.45
Hi krass, it's looking great! For a high density file one thing that can help is to adjust the display mesh density to be looser so that you will have fewer triangles generated for the shaded display mesh.
To do that, go to Options > View > "Meshing parameters", and set "Mesh angle" to 25 degrees and uncheck "Add detail to inflections". That may help to speed up your display.
Also one of the new things for MoI v3 is that it can use multiple threads for the display engine to help speed up the display too.
5991.47 In reply to 5991.46
Hello, Michael!
Thank you very much for the advice - I will take your recommendations!
Unfortunately I do not have the possibility to move to version 3.
Maybe someday in the future.
The more I work in your program, the more I see the beauty and possibilities, thanks! MOI3D gorgeous!
5991.48
It pleases the fact that imports Keyshot for fast imaging occurs without problems.
It's also nice that Keyshot understand the details of the different colors MOI3D file that allows you to quickly assign the necessary procedural materials. Very convenient.
EDITED: 1 Sep 2022 by KRASS
Size: 1.1 MB, Downloaded: 103 times, Dimensions: 2500x1759px
5991.49
Getting to the top of the locomotive: a viewing platform with a fence around the boiler
Size: 1.1 MB, Downloaded: 118 times, Dimensions: 2464x1547px
5991.50
Hello everyone!
I decided to add some images of the work process.
I hope it is someone like))
Size: 550.5 KB, Downloaded: 42 times, Dimensions: 2600x1904px
Size: 917.2 KB, Downloaded: 81 times, Dimensions: 2500x1831px
Size: 1 MB, Downloaded: 75 times, Dimensions: 2500x1831px
Size: 655.7 KB, Downloaded: 42 times, Dimensions: 2500x1831px
Size: 247 KB, Downloaded: 42 times, Dimensions: 1920x912px
Size: 467.9 KB, Downloaded: 46 times, Dimensions: 1920x1406px
Size: 567.1 KB, Downloaded: 67 times, Dimensions: 1920x1406px
Size: 389.4 KB, Downloaded: 44 times, Dimensions: 1920x1406px
Size: 252.3 KB, Downloaded: 41 times, Dimensions: 1920x1406px
5991.51 In reply to 5991.50
It's looking really great krass!
5991.52 In reply to 5991.51
Thank you, Michael!
It's all thanks to the magic of your program: work very convenient, fast and easy. A real pleasure.
In 3D max I would have gone crazy))
5991.53
Lanterns on the bumper bar of a steam locomotive.
EDITED: 17 Jun 2015 by KRASS
Size: 802.2 KB, Downloaded: 71 times, Dimensions: 2500x1936px
Size: 815.5 KB, Downloaded: 125 times, Dimensions: 1920x1334px
5991.54 In reply to 5991.53
Bravo!
5991.55 In reply to 5991.54
Hi, Frenchy Pilou! Merci! :))
5991.56 In reply to 5991.53
Excellent modelling :)
Martin
(TpwUK)
5991.57 In reply to 5991.56
Thank you, Martin! I did my best;)
5991.58
A small experiment in texturing models MOI3D.
1. Export from MOI3D to UVLayut - .OBJ-file settings:
output: n-gons
Angle: 6
Weld Vertices - ON
Avoid smaller: 2
Aspect ratio: 2
2.Next - open the file with UV-coordinates in Substance Painter
3. And - voila!
Size: 436.2 KB, Downloaded: 129 times, Dimensions: 1170x902px
5991.59 In reply to 5991.58
It looks awesome! Very nice structure. Also whole train mechanism is very nice :)
https://twitter.com/VojtechLacina
A revival of this ? ;)
5991.61 In reply to 5991.60
Frenchy, I appreciate your joke, colleague! )))
5991.62 In reply to 5991.59
Vojtisek, thanx`s!
This is only a fragment - I test methods for texturing.
Prior to the "full train" still very far away)))) But - thanks for the high score!
Show messages:  1-2  3-22  23-42  43-62  63-68
