Hi sosodef,
> it is about the same model which i uploaded before in this Thread. It is
> about the "weird lines" object.
Ok, but you never attached the 3DM file for this model, as far as I can see you only attached the OBJ file. I can't try to fillet the OBJ file, I need your 3DM model file in order to look at any fillet problems.
> If yes, isn´t 0.01 mm filet also pretty close to a really sharp edge ?
It depends on the particular scale of the particular model.
It's hard to give you any good information without being able to examine the 3DM model file that you're having problems with. Please post the 3DM model file (not just the meshed OBJ one) and that would help me to be able to take a look at what you've got and try to give you some tips.
