Planar quadrangles
 1-14  15-33
5959.15
Hi Michael, thank you for your comprehensive answer. I will read it later.
Meanwhile I think, I came nearer to a solution. I draw lines and projected them on the surface. The result is very good, accept the ends of the projected lines, the red circles shows it, should meet themselves where the arrow is. Any suggestions?
Rudl
Size: 73 KB, Downloaded: 44 times, Dimensions: 1436x890px
5959.16 In reply to 5959.15
Hi Rudl, the problem with the projection method that you show there is that while yes you're getting 4 sided areas, the sides are all curved and the 4 corner points are not going to be all one one single plane...
Is a result like that ok for what you need or do you need to have 4-sided planar pieces which is what I thought you were looking for?
5959.17
No, it was not that what I´m looking for.
I thought, this could be the way how planar quads should be located. But they don´t want.
Rudl
5959.18 In reply to 5959.17
Hi Rudl, yeah if you need planar quads then you'll just can't really use any method that generates curved shapes like that projection does, things that are all curvy will not be planar at the same time...
You probably need to think more about starting some piece of the construction with a plane itself and then generate more pieces by something like intersecting that plane with other parts, that way you know that the result is planar. That's basically how the method that I wrote above works, I think that may work for you...
In fact you want something like to cut a diamond ?
5959.20
.....In fact you want something like to cut a diamond ?
This is a good comparision
5959.21
Hi Rudl,
not sure if this is what you want but it is made up of planar faces.
I constructed a polyline going thro the points shown on your drawing ie base curve
and another on the Z axis curve.
Extrude the base polyline along the path of the Z axis polyline and then trim to
120 degree.
Barry-H
EDITED: 30 Jan 2021 by BARRY-H
5959.22 In reply to 5959.21
Cool but all facets are not all "quadrangular" on the 120° arc face!
5959.23
I meanwhile have found this soluion.
5959.24 In reply to 5959.23
Looks good Rudl! Just be careful - only having 4 lines on the outside of a surface does not just by itself make a surface to be planar. If you're using a construction tool like sweep or network to build a surface between any 4 lines it's pretty easy for that surface to be warped in some way instead of being flat.
If you created all those surfaces by using Construct > Planar or Draw solid > Plane then it should be ok though.
Bravo!
As always, that was very simple but some headache for find it!
And that is "cutting" diamond!
And Lineweb works fot that! ;)
In twice for special threatment for the top!
5959.26
The lower rows I made with plane through 3 points, scaled them up, intersected them and trimed them. The top I made with a polygon and filled it. I had a lot of try and error, finally the sequence was important.
Rudl
5959.27
Yes, lineweb helped. It was a mixture of the suggestions I got.
5959.28 In reply to 5959.27
5959.29
hallo FP,
lineweb did not make planar quads. It was just for orientation.
Rudl
5959.30 In reply to 5959.29
Hi Rudl, yup that's right - LineWeb just makes a bunch of lines, and just having any 4 lines connecting end to end does not by itself mean that they are planar.
It sounds like you have taken all of this into account now with your final result though, I'm glad you were able to finish it! :)
5959.31
yellow is lineweb.
5959.32 In reply to 5959.29
Works if each side have the same measure! (so I can't obtain exactly the same result than your :(
And polyline N°1 is rotated from an external center!
Each facet is planar but Planar function itself can't work for all facets in one click because some segments are not doubled! :(
EDITED: 18 Jun 2013 by PILOU
5959.33 In reply to 5959.32
Hi Pilou, yes for the special case where each polyline that you created like that is an exact copy of the other and only rotated that will work, but that's pretty different than just running line web on a series of general curves. In the general case doing lineweb between any kind of smooth curves you will not likely get planar results.
Show messages:  1-14  15-33
