Startup zoom
All  1  2-7
5958.2 In reply to 5958.1
Hi Didier, if you get the views set up how you want them you can then save a 3DM file, and then use that 3DM file as the startup template. Then your initial view setup (and various other things like default Styles too) will come from that file.
You can set the startup template under Options > General > "Template file".
It doesn't really matter where you put the template file, just save it in some place where you won't likely delete it later on.
5958.3
Yes ! I had not thought of template file...
Thank you Michael !
5958.4
Finally!
After all this time, I broke down and set up a "Default.3dm" template file. :-o
I made up two dozen colors for the materials bank which should come in handy for bouts of creativity.
And... if you want to bring your default colors into any existing model, simply go to Import and choose your "Default.3dm" template file.
EDITED: 15 Jun 2013 by MAJIKMIKE
Cool tricks!
And for the colors you can name your default .3dm following that you have made and import it! ;
Spring.3dm, summer.3dm, autumn.3dm, winter.3dm...
Some colors: http://colorschemedesigner.com/
http://www.colorschemer.com/online.html
5958.6
5958.7 In reply to 5958.6
i have put up a RAL Design template some time ago. might be useful for architectural work.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5413.1
Show messages: All  1  2-7
