Maintain Tangent on sweep
All  1-3  4-8
5951.4 In reply to 5951.3
Now I understood!
I look at this picture and can not understand what you sweep and than how you make thiss mirorred object.
I thought that rails lay on the same floor and it confused me. I think the angle of this picture is not very good as may confuse people.
Now I understood it clear and will use it, useful function.
5951.5 In reply to 5951.4
Yeah in that picture there, one rail is flat on the world x/y plane and the other one is vertical. A lot of times it can be hard to see what's going on in 3D without being able to rotate around and look from different angles.
5951.6 In reply to 5951.4
"""""""""I look at this picture and can not understand what you sweep and than how you make thiss mirorred object.""""""""""
Looks like a good candidate for "rail revolve". Mirror the bottom rail and join it, then do a rail revolve on the arc, setting the bottom as the rail. No need to sweep and mirror and construct.
5951.7
Hi Andrei:
here is an example about "mantain tangency" making a simple bike's saddle.
Both sweep examples (-B-C-) using same splines
Also Burr's suggestion with rail revolve instead of sweep.(magenta line is rail revolve axis)
you can see three different results
have a try with my file attached,if not clear
M
(..oopss..forgive me for grammar error..is MAINTAIN..)
5951.8 In reply to 5951.7
Hi m-dynamics,
thank you good example)
Show messages: All  1-3  4-8
