holes and booleans
All  1-9  10-17
5934.10 In reply to 5934.9
<< I guess you are asking about something like an "autoclose"?
yes absolutly! :)
5934.11 In reply to 5934.9
A little video is always wellcome!
I am interested of your drawing lines / curves surrounding edges for the numerous (or not) closing holes on the sides!
5934.12 In reply to 5934.11
Hey Frenchy,
Here's a short video using a couple scripts:
I used points to mark the start of the openings so I knew where to blend. It could help if there were "many openings", but at the same time, selecting that boundry would be tedious, if there were many of the little openings. Not sure of any way to automate that. I would guess there really isnt any need for the boundry to be "Not a square", so I would just use the rectangle tool and go from corner to corner on the surface and use that to trim. Just running the "untrim the outer edges" script only.
Anyway.......
5934.13 In reply to 5934.12
Thx for the video!
Cool trick to write some words on the screen for help to see the actions to make!
Any reason for make an extrude and not directly a simple Trim with the "rectangle"?
And yes an automatic close a set of lines will be useful ! (Merge function don't work in this case :(
5934.14 In reply to 5934.13
""""""""""""Any reason for make an extrude and not directly a simple Trim with the "rectangle"?"""""""""""
I had some issues with using the curve. I probably could have "flattened" it and had it work. It's just a method I use when I have problems with the trim curve because it seems to be a more "direct trim" as opposed to the "projected" one. Maybe Michael can comment on this. Like "having the trim curve be non-planar made it a different calc or something.
5934.15 In reply to 5934.14
""""""""" It's just a method I use when I have problems with the trim"""""""""""""
..i do the same..
i think cutting surface must penetrate into other surface,when last one is complex
i suppose that trim using just a curve project a lot of points,and if the target is ondulated or complicated,tool not project enough points to cover all the wavy:so trim fails.
(this is just my deduction,forgive me if is not correct)
thanks Burr for your tuts,i learned few fundamental tricks in the past
just don't know why you don't speak also...it's your leanguage!!! (i must do lot of effort to speak in English when i record my modeling sessions...damn...)
5934.16 In reply to 5934.14
Hi Burr, yeah a trim curve that is non-planar goes through a much different process than a planar one, it tries to get the curve onto the surface by a process of pulling it down along the surface normals, but that process in the geometry library only works very well currently if the curve is really pretty close to the surface already. If it's a fair distance away it tends to make squiggles in the curve. I've been planning for quite a while to overhaul that particular "pull down 3D curve to surface" mechanism.
5934.17 In reply to 5934.15
""""""just don't know why you don't speak also..""""""""""
I'll try to remember to speak in them. I guess it can help some with alot of the little stuff.....
Show messages: All  1-9  10-17
