Imort file problem
All  1-9  10-13
5933.10 In reply to 5933.8
After opening the file, please they press the reset button on the viewport.
(after loading the file, model is not centered on the coordinate plane and therefore not visible on viewport)
-EDDI
5933.11 In reply to 5933.9
Hi Michael, the problem was in file path one of the folder was named in not ascii characters. Thanx.
The reason I'm not using v3, is that I cannot install any soft here in my work place but v2 was already installed.
5933.12 In reply to 5933.11
It's possible to run v3 without actually "installing" it - after you've done the v3 install at home, copy the entire folder (like c:\Program Files (x86)\MoI 3.0 beta Mar-17-2013) including all sub-folders onto a USB key drive, then at work just copy that same folder onto your desktop or documents directory and you should then be able to run the MoI.exe that's in that folder.
That should work for running MoI v3 on your work machine even if your IT department has disabled admin rights and so you can't run regular installers, unless they have some other more unusual kinds of system locks in place.
5933.13 In reply to 5933.12
Thanx, I'll do it)
Show messages: All  1-9  10-13
