More fillet troubles...
All  1-6  7-8
5898.7 In reply to 5898.5
Ok, good to know! I guess the best way, I can think of, to do it differently would be to fillet every edge like you did, delete the unwanted faces, then boole union with the other piece, and it worked! Sometimes bugs are good because they allow you to adapt to different situations and come up with a different way of doing things. (: Thanks for the help Michael!
Size: 277.7 KB, Downloaded: 46 times, Dimensions: 1351x846px
Size: 547.1 KB, Downloaded: 56 times, Dimensions: 1260x788px
5898.8 In reply to 5898.7
Hi Shazbot, yup sometimes if you can get just some fillet pieces from somewhere else it's possible to splice those into place using trimming or booleans.
That's why if the filleter failed to figure out how to finish everything up but was able to generate some fillet surfaces it will try to spit out those surfaces so you might have a chance at still using them.
Your model is coming along nicely!
Show messages: All  1-6  7-8
