Pure awesomeness
All  1-7  8-14
5880.8 In reply to 5880.7
I am really curious about how the Blender normal improvement will work out.
I noticed with a different model that the shading artifact is there because of a rough geometry.
In general the NGON exporter for this shell works extremely flawless.
Just those corners have issues. As marked in the image adding more geometry and then also
moving the vertices so the flow / surface continuity is better extremely helps with removing
the shading artifact which in this case is simply because of some choppy and impossible to shade
smooth parts.
Michael is in such a situation it possible to have the side shells mesh as is but have more subdivision
along U or V of the edge rounding geometry so that the mesh flow between sides and edge is more
consisten?
5880.9 In reply to 5880.8
Hi Claas,
> consisten?
It's unfortunately quite difficult to have the mesh created as if it had human judgement about where to place vertices.
In the general case there is not necessarily any special U/V alignment between different surfaces, start drilling some holes through your blend areas and you can easily see what kind of general geometry the mesher has to be able to deal with.
It could be possible in the future to have special case handling of certain situations, but they have to be detected and categorized properly and it's not easy to do such things.
5880.10 In reply to 5880.9
I fully understand I was just curious. The hand adjustment of the mesh can often fix some of the bad artifacts while this way maintaining also a less dense polygon mesh for rendering.
However if time is an issue I tried out the edge settings and those problems often disappear once a certain mesh density is reached and the surface flow is amazing - just the file size increases.
But this is both fully workable, NURBS to render polygon is just a matter of making trade offs before your lock up your computer because you ran out of ram, hahaha
Happened to me twice this night.
Thanks again for this wonderful mesher!
How complex is actually the math behind this? I can only imagine that this must be an incredible tough job to translate a NURBS data into a polygon mesh.
5880.11 In reply to 5880.10
Hi Claas,
> size increases.
If the proper vertex normals are used, it's a much different situation and even quite rough low polygon count meshes don't have these particular kinds of shading artifacts, then you only need to make heavier meshes to make silhouettes less pointy.
So again I really recommend using a renderer that supports vertex normals importing, which is basically any renderer at all except Blender currently. Hopefully Blender will be able to hit that target in their planned update, it will really make a significant difference in render quality when rendering CAD data.
It's a quite complex overall process, especially with making things making things to be able to work with all kinds of geometry.
This one particular area of mesh generation is probably the single most time consuming individual feature area that exists in MoI, I'd say about 8 or 9 months of full time work has gone into just this one particular area alone. But it's resulted in a quite unique mesh generator, other NURBS meshers do not natively generate n-gons like MoI does and instead connect interior mesh vertices to edge boundary ones using triangles and it's easy for that triangle connection area to be kind of messy. Not just in topology but also in shape as well, like with Rhino the edges get meshed to certain tolerance settings, and the underlying surface gets subdivided to certain tolerance settings but then when the outer edge boundary vertices get connected to the interior "underlying surface" vertices, those connector triangles can cross too large of an area and form a kind of divot in the mesh , basically the triangle connection pieces easily go out of the tolerances that were used for other parts of the meshing, making a visible indentation in the mesh shape. There are quite a few people who use MoI just for mesh generation to go from other CAD programs into polygon data because of this.
EDITED: 16 May 2013 by MICHAEL GIBSON
5880.12 In reply to 5880.11
Thank you for all the help and explanations.
5880.13
Does anyone know if vertex normals have been fixed in Blender?
If so, what version of Blender? And can someone please post a URL where I can read about this?
Thanks...
5880.14 In reply to 5880.13
Hi YHWH_777,
I think the latest thing I've heard is that vertex normals are not discarded when you render anymore so that part is fixed. But I think you still have to make modifications to the importer in order to actually get them read in.
The latest discussions I know on it are here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6003.1
http://www.blenderartists.org/forum/showthread.php?299193-Modified-OBJ-Importer-for-Custom-Vertex-Normals
Show messages: All  1-7  8-14
