Clothoid 2 point curve script
 1-5  6-25  26-35
5878.6 In reply to 5878.5
Thank you for your help. I'm still studying your messages.
Installed MoI version 2 on the new hard drive.
The jscript picked up the error in the following code at line 334(plus)
return { 'K': K, 'Kprime': Kprime, 'L': L, };
Note the final comma after L -----The comma should not be there.
This error was not found in the current MoI Beta3 javascript. (webkit?)
Removed the comma, and the script runs in Moi version 2, when both points are selected in Top View plane, z=constant value,
or Front View, y=constant.
Right view does not work properly. Either var cplane = pointpicker.ptframe;, and evaluate do not work properly in
Right view, (1% probability?), or the script is defective, (99% probability?).
5878.7 In reply to 5878.6
This probably depends on which version of Internet Explorer and JScript.dll are installed on your system that v2 ends up using.
What you have there is a "trailing comma", and I think it's supposed to be ok but some versions of the IE scripting engine do not allow it. This difference in behavior in IE scripting compared to other script engines sometimes causes grief for web developers, if you do a web search for "jscript trailing comma" you can find some stuff about it.
I'll take a look and see if I can figure out what's going on.
5878.8 In reply to 5878.6
Hi Brian, ok so I think the problem is the script is not quite getting the correct 2D coordinates for doing your calculations.
At the start of your function buildClothoid you've got some calls to cplane.evaluate() there - but that's probably not right, you use cplane.evaluate() for converting from the frame's "local coordinates" into world coordinates.
At that point in the script for buildClothoid() you actually need the reverse I think - the points given to you by the pointpicker are in world coordinates and you want to get them into 2D coordinates within that cplane's local coordinate system before you start doing calculations with them. Then when you're done doing your calculations that's when you want to use cplane.evaluate() to convert from 2D local cplane coordinates back into world coordinates.
The .evaluate() call is only for doing the last part (2D local into 3D world conversion) - you need something different for the first part (3D world into 2D local cplane conversion).
For doing the 3D world into 2D local conversion you can get the local 2D plane coordinate from a 3D world coordinate by doing cplane.distancex() and cplane.distancey() which get the signed distance of the given 3D point from the x-axis plane and y-axis plane of the frame, something like this:
var localx = cplane.distancex( worldpt );
var localy = cplane.distancey( worldpt );
So if you use that in the start of buildClothoid() it should then give you uniform behavior in all views, here's an updated buildClothoid function that should work:
function buildClothoid(BasePt, theta0, OtherPt, theta1, numintervals, cplane)
//Convert to cplane frame.
	var base_x = cplane.distancex( BasePt );
	var base_y = cplane.distancey( BasePt );
	var other_x = cplane.distancex( OtherPt );
	var other_y = cplane.distancey( OtherPt );
	var deltax = other_x - base_x;
	var deltay = other_y - base_y;
	var r = Math.sqrt( (deltax * deltax) + (deltay * deltay) );
	var phi = Math.atan2(deltay, deltax);
	var deltaphi = normalizeAngle(theta0 - phi);
	var deltatheta = normalizeAngle(theta1 - theta0);
	var Aguess = 2.4674 * deltatheta + 5.2478 * deltaphi;
	var A =	findA(Aguess, deltatheta, deltaphi);
	var a = 0.0;
	var b = 1.0;
	var maxR = 50; //maxrecursion
	var L = r/ adaptiveSimpsons(A, deltatheta, (deltaphi + Math.PI/2), a, b, maxR );
	var K =	(deltatheta - A) / L;
	var Kprime = (2*A)/(L*L);
	return 	{ 'K': K, 'Kprime': Kprime, 'L': L };
Hope this helps!
Looks like some cool stuff! I wish I had more time to experiment with some stuff in this same area as well myself.
5878.9 In reply to 5878.8
Thank you very much Michael.
I was using the spur gear script for a "pattern"
What you are saying makes perfect sense.
hmm... I'm thinking that BasePt is at cplane 0,0,0, so base_x = base_y = 0 (?)
Report: Made the recommended changes, and they work correctly.
Uploaded corrected script.
Still need to work on other point picking permutations.
-Brian
5878.10 In reply to 5878.9
Hi Brian, you're welcome!
Yup, I think that should be true, you could just set those to 0 if you want in this case since you know BasePt is right at the cplane's origin point.
Added "GetCircle" selection behavior for point selection in two different views.
The end point is entered first, then the start point.
Posted updated script to first post.
It looks like only about 6 or less downloads have occurred, so not very many people have the older versions.
5878.12 In reply to 5878.11
I like the new iteration.
"The endpoint is selected first"
Works as before. If you select the start first, the direction in the viewport quadrant will produce different results! Kindof neat.
5878.13 In reply to 5878.12
Thank you BurrMan.
I was just comparing the curve to a 2d Blend curve.
I wonder what code it would take to Bind and move an end point around?
5878.14 In reply to 5878.13
Posted version 2b, with two slight changes. See first post for details.
5878.15 In reply to 5878.10
Hi Michael
Is there some way to get the end point tangent of a curve, by script?
I was thinking of correcting the interpcurve version of a clothoid curve between two existing curves, and to
correct the slight errors in the beginning and ending tangents by doing a MoI Blend between the start point, and the second interpcurve point,
and also a second Blend between the next to last point, and the end point.
Or maybe there should be extra points between the beginning and first point, and also between the next to last point, and the end point?
I have read that for these types of curves, it is not possible to perfectly display the curves by NURBS, but only to within some tolerance?
Also wondered if you will be improving the slide bars for scripts, as the sliders that you do for your factory commands work so much better?
Thank you
-Brian
5878.16 In reply to 5878.15
Sorry no there is not currently any curve tangent evaluation set up for script access.
Yeah that's pretty common, usually any specific kind of curve can't be 100% exactly represented by a different kind of curve but can be approximated using a bunch of points to some tolerance level.
NURBS curves can exactly represent conic section curves though.
Probably what you're running into here is that the script is running in a separate process so every call that it makes into MoI has to do some inter-process communication. But it's also why a command script can't easily crash MoI, because the separate process that the script is running in can be just torn down without really needing any cooperation from the script itself.
One thing you could try is to put more of the logic into a <script> tag inside the .htm file - that will run inside of the main moi process and won't have to do any inter-process communication when it makes calls into moi.
5878.17 In reply to 5878.16
Michael, thank you very much.
I'll have to learn more about how *.htm files work, and how they work with MoI.
-Brian
5878.18 In reply to 5878.17
Hi Brian, *.htm files for commands in MoI are the same as HTML files that are displayed in web browsers, the upper-right area of MoI's main window basically has an embedded web browser there that loads the HTML content. You can also have script in that HTML content same as you can in HTML files that are displayed in a regular web browser. There are a few different ways that scripts can be declared on a web page, it's possible to have an event handler declared in something like an onclick="" attribute on a button but if you have some pretty big functions it's more typical to have those functions declared in a <script> block that you put in the <head> portion of the HTML page.
The command script (the .js file part of a command) can call script functions that are in the HTML page, the root object of the HTML page is available under moi.ui.commandUI , and any script functions declared on that page end up as global variables there, so if you have a function in HTML called blah() like this:
    <html>
        <head>
              <script>
                  function blah()
               </script>
        </head>
That function defined in the HTML file can be called from the .js file by: moi.ui.commandUI.blah();
I've attached an example where I've edited your Clothoid2ptDraft2b command to move a bunch of the script construction logic over into the HTML file which is then called in this manner from the .js file.
The script code that is declared inside of the HTML file will have fairly different performance characteristics than the code that's run in the .js file - that's because the HTML page runs directly inside of the main MoI.exe process, while a regular command's script file runs in a separate process: moi_commandprocessor.exe and it talks to MoI.exe whenever you make calls into any MoI object. The main reason for this inter-process communication is to make it harder for scripts to be able to crash or lock up MoI, with the script being in a different process it's a lot easier for MoI to forcibly terminate that script at any time without anything happening to the main moi.exe process.
Script code that you run directly inside of the main MoI process will have less overhead to each MoI object call that's done in it, but it will also be easier for the script to lock things up if it goes into a tight loop or things like that as well.
In the future I'd like to make a type of "script factory" mechanism that would make it possible to write some script that would run in a separate worker process but have in-process calls for geometry access and vector math type functions so that the script would not have as much overhead.
The way regular MoI commands are set up though the scripts are mostly used for control flow logic and not for doing heavy duty calculations directly in a script - heavy calculations happen in the geometry factories that are currently written in C++ and they have that kind of direct geometry access even though they run in a separate worker because any geometry that's being used by the factory is sent over to the worker process so that it can then access it locally as it does calculations on it.
So anyway basically right now things are not really optimized for the case of doing heavy calculations directly in script, but you may get some lower overhead for scripts that are contained inside of the HTML part of the command which is normally where the UI controls go. You can have script code in there as well though if you want by using <script> tags. Hope this explains a bit more of how things are currently set up to work.
5878.19 In reply to 5878.18
Michael, thank you very much for these details.
I'll study them after work...(I've been to busy to do much lately.)
There is a new paper called "Super Space Clothoids," which are 3D, but the math is very difficult.
http://hal.inria.fr/docs/00/84/03/35/PDF/eulerspiral.pdf
-Brian
EDITED: 9 Jul 2013 by BEMFARMER
5878.20 In reply to 5878.19
Made in France! :)
5878.21 In reply to 5878.20
..French Pride.. ;) :)
5878.22 In reply to 5878.20
Oui :-)
After a long hiatus, spent a few hours adding two sliders for the start and end angles of the clothoid.
It only took a few minutes to add the sliders, but a lot longer to get everything working more or less properly,
due to limited programming skills and limited understanding.
Much of the code is in the htm file, as per Michaels post.
The MoI3 version of Blend command was used for the basic pattern, but had to modify it per Michaels help of many months ago, since
the sliders do not have a "clothoid factory" to work with. The sliders work "better" in Blend command, (in my opinion).
Is there some way to make the clothoid sliders update interactively, not just when the mouse button is released?
Angles can also be typed into the boxes.
The MoI3 version does not quite work in MoI2. MoI2 hangs up for awhile, but then permits exit from MoI2.
The MoI2 version of Blend appears to have a different line in the slider code.
Including this difference allowed a version that works in MoI2, and it also worked in MoI3.
Attached a MoI3 version, and also a MoI2 version, both with limited testing
Edit August 2, 2013...See August2 post for updated onmousemovevaluechange sliders for MoI3August1Beta.
EDITED: 3 Aug 2013 by BEMFARMER
5878.24 In reply to 5878.23
I'm sorry there's not any way to do that currently, at the moment the interactive slider stuff is only set to work through the property binding mechanism so it will only work for binding to a geometry factory input, not to trigger a script event for the interactive movement.
I'll see about putting in an option for the slider for generating continuous events for every mouse move.
5878.25 In reply to 5878.24
Thank you.
Show messages:  1-5  6-25  26-35
