Export flat planar surfaces as illustrator lines
All  1-9  10-12
5855.10 In reply to 5855.9
Yes Michael but I only plan to export planar surfaces and not volumes so overlapping edges are not a problem :)
Each face would have their own edges so they can be filled with a color in illustrator, that would be cool.
For now I use the convert face to edges script then export to .AI, it's working ok.
shapenoid.com stojan-voumard.com
5855.11
Thanks Martin, looks like you beat me to it! Oh, and Michael, great to hear you're looking to expand the 2D export. Ai-export is great, but perhaps you might find PDF more approachable to add these features?
/ Fabien
5855.12 In reply to 5855.11
Hi Fabien,
Unfortunately PDF is in general a massive increase in complexity (file structure wise) from the old AI format so everything is more difficult with it. I do want to implement a PDF export in addition to AI8 format export and I have some new PDF support stuff in place that should help me do that but I should probably try to get colors working in AI8 first before digging into the PDF export. Some things at a low level in PDF resemble AI format so getting it working in AI8 may also give me kind of a running start as far as figuring it out in PDF later on as well...
PDF import has already been significantly overhauled in MoI v3 a few releases ago to use a proper PDF parser so the import side for PDF is working much better now.
Show messages: All  1-9  10-12
