UV generation & OBJs
All  1  2-5
5836.2 In reply to 5836.1
Hi Paul, that's odd - MoI should only be exporting UV coordinates within the 0 to 1 range, but every surface in the model overlaps on to the same 0 to 1 square so they all share the same UV area rather than each piece having its own separate little partitioned island.
What happens if you export just a simple single box, do 3DCoat and Softimage 2014 have problems with that as well or is it only with some particular model? If it's with one particular model can you please send the 3DM model file and the generated OBJ file to me at moi@moi3d.com so I can take a look?
I guess probably these programs have become sensitive to having many polygons sharing the same UV area.
It is possible to disable writing UV coordinates with OBJ export by a setting in moi.ini - go to Options > General and push the "Edit .ini file" button near the bottom. Go to the [OBJ Export] section and there is a setting there for WriteTextureCoordinates=y - change that to be =n like this:
[OBJ Export]
WriteTextureCoordinates=n
You can also disable writing materials (what I think you're calling surfaces), under Options > Import/Export > OBJ options > "Write material assignments".
5836.3 In reply to 5836.2
I have the same issue when importing a MoI .lwo file into 3D-Coat.
MoI Version 3.0 Beta Mar-17-2013.
I tried a box in .lwo and .obj format with the same results.
The attached image shows the MoI UV's after import.
EDITED: 21 Apr 2013 by BISENBERGER
Size: 299.4 KB, Downloaded: 45 times, Dimensions: 1756x471px
5836.4 In reply to 5836.3
Hi bisenberger,
It sounds like it does actually import though, it just shows that message first?
Since 3D Coat has become more sensitive to having problems with certain UV structures, you may want to disable writing UV coordinates out from MoI and instead create the UV coordinates after the import.
To disable writing UV coordinates out from MoI, open up the moi.ini file by going to Options > General and push the "Edit .ini file" button near the bottom.
For OBJ format, find the [OBJ Export] section and set:
[OBJ Export]
For LWO format, find the [LWO] section and set:
[LWO]
With MoI's built in UV coordinate generation turned off it should avoid that warning message when you then import into 3D Coat after that I would think.
5836.5
Yep, it looks like 3D-Coat has become sensitive in this regard. No problems opening the .obj or .lwo with modo.
Changed the settings in the .ini as you outlined and no more message. 3D-Coat now defaults to Auto-mapping when I open it, Super cool!
Bill
Show messages: All  1  2-5
