reset position
All  1-3  4-6
5833.4
This command will center your object at the origin point :
http://moi3d.com/forum/index.php?webtag=MOI&msg=2409.1
I often combine it with "Put on Ground" :
http://moi3d.com/forum/index.php?webtag=MOI&msg=5427.13
@ Michael,
By the way, is there a possibility in MoI to run two scripts in sequence. For example A shortcut that would execute the script "CenterAtOrigin" first and then "PutOnGround" ?
Schbeurd
Happy MoI user since beta version of August 13 2006...
5833.5 In reply to 5833.4
Hi Schbeurd,
> Thanks
There isn't any sort of bundled up way to do that currently, because things happen asynchronously. I'll see about adding in a method for a script so it can wait for the current command to be finished, that should then make it possible to make a combined scripted sequence on a single shortcut more easily.
5833.6 In reply to 5833.5
That would be great !
Thanks Michael
Show messages: All  1-3  4-6
