art-relief on a surface
All  1-4  5-9
581.5 In reply to 581.4
Michael,
I meant the outer countour (in the sun).
And yes, I got the problem that if the radius is bigger than the actual piece, will not work....
Any idea why the outer countour will not filet? Perhaps some sharp curves, causes MOI to think there is no room to filet properly....
Also, take a look at this file.
I have fileted the different solids OK, except the smaller free form.
Do not have any idea why...
Rudy
581.6 In reply to 581.5
Forgot the file
Rudy
581.7 In reply to 581.5
Hi Rudy, it does seem to fillet ok over here if I use a radius of 0.01 or 0.02 - but not anything much larger than that.
Does that not work for you?
Sometimes you have to go pretty small with the radius.
Oops, doesn't look like the file got attached, can you re-post it?
581.8 In reply to 581.5
In this case it is due to the shape not being entirely smooth, there are 2 spots where it comes to a sort of shallow sharp point.
This is another situation that complicates things for the filleter - when things are completely smooth it generates a simple fillet as a single piece. When things aren't smooth, the filleter has to try to extend and intersect the fillet pieces and doing that at shallow angles tends to be somewhat unreliable.
As you can see, it is not difficult to have situations that won't fillet well. Shapes that don't have unnecessary sharp bits or unnecessary edges in them will tend to work better.
581.9 In reply to 581.8
Thank you Michael,
I got the lesson.
And yes, I did filet the outer sun contour with a radius of 0.015 ...everything is working well...learning....
Thank you very much!
Rudy
Show messages: All  1-4  5-9
