"""""""""(I had to move the lines to 0,0,0 as they were at some ridiculous coordinates) """""""""""""
Hi Val,
Would you be willing to generate the 3d contours at those original coords and put that here? I just got flat stuff in my dxf conversion, but I have generated a surface from the land coords that sits out in that "far off location". Because the Elevation data is very small, I am having an issue with matching the surface to your lines. I gets complicated when dealing with projection data and all the variables. I will be scaling my surface result in the Z value to match the contours you have, but I need them to be in the same place, or I cant tell if I have it close or not.
