Need help !
 1-5  6-25  26-29
5795.26
Hi everyone,
Thanks for all the help ! I finished the trainstation model today and now I'm starting to build the stuff around
Is anyone kind enough to convert those to .3DM ? I only need the curves and the buildings, I will open them in rhino and generate the terrain with the patch tool (maybe before I'll clean all the lines)
Then I will manually place the buildings on the ground :D Fun part (could do it with grasshopper)
I found a video tutorial about the patch tool it seems to work great if curves are clean and if you first do an extract points.
https://dl.dropbox.com/u/44982094/CEVA_EAUX_VIVE_DXF_MULTIFACES.dxf.zip
https://dl.dropbox.com/u/44982094/CEVA_CHENE_DXF_MULTIFACES.dxf.zip
https://dl.dropbox.com/u/44982094/CEVA_BACHET_DXF_MULTIFACES.dxf.zip
Thank you :)
shapenoid.com stojan-voumard.com
5795.27 In reply to 5795.26
Hi Desudeus, Rhino should be able to load the buildings from the DXF file - when I tried it looked like the buildings were made up of polygon data, which is why they don't come into MoI v3's new DXF reader, MoI's reader seemed to bring in the curves ok though.
But if you're already going to use Rhino for the patch terrain method, you should also be able to use it for importing that DXF file as well too.
5795.28
I think some confusion might be that the location of the drawing is so far away from 0,0,0. as I opened it in Moi and initially didn't see anything.
I had to look at it in Max first and find out that the location is 208679'6.5", 93074'4.75", 34' 8.5"
http://www.suburbanartworks.com/
5795.29
Got the terrain made, buildings imported, I'm now projecting the streets onto the terrain :D
My computer is crying from the load... And it's a 12 core...
Show messages:  1-5  6-25  26-29
