Quite special geometry, how to approach it?
All  1-7  8-14
5791.8
Heiner,
Maybe you should consider an analytical approach. Or in other words, just build your shape using basic boolean methods:
I made the top and bottom surfaces, which were more broad. In this case, I extruded two curves, but a smooth and simple Network of what you would like to portray as far as the overall shape would do.
From the top view, I made three curves representing the curvy areas, three lines to represent your openings, and an Inset (offset) of the curves to represent the inside.
I trimmed the top surface with the more inner curves and kept that shape.
I extruded the more outer curves downwards, then I trimmed them with the bottom surface. I also derived my bottom surface shape from those curves.
I then Blended surfaces between the edges of the more smaller top shape and the vertical surfaces of the extrusions.
I did some extra trimming, but then I was able to join everything together.
I used the straight lines to trim the openings.
The bottom had a sharp lip and I applied some fillets.
So with some brute basics, I was able to outright create a shape close to maybe what you were envisioning.
But like Michael mentioned, the more organic a direction you intend to take, the more you may have to consider D-Sub like applications such as T-Splines which takes a more organic approach.
Another example:
5791.9
Hi to all of you,
and first of all a great THANK YOU! With your input, i really have the feeling, as if i can manage to get that thing done!
@Michael: You are right, that thing is there already as a polygon modell, and the model included in the file is a "rough" version for
tracing purposes. In fact, i am quite good in polygon modelling- The piece here is something, which is going to be produced.
The company which we want to do the production asked for a STEP file and a NURBS model for doing the cost estimate.
Besides that i considered the whole thing a good occasion to learn NURBS modeling, which is with MOI a pleasure. Your
mentioning of T-Splines is interesting, because i am monitoring these for quite some time, but was not able to raise the funds
to get them (Besides they are Autodesk now, which is a company i am not too fond of). But while we are at it, i like
the concept of the T-Splines, and I belive it is inspired by the patch modelling of Animation:Master which has a spline
based modelling, which is on a certain level very much like NURBS modelling, but much more flexible. Just look at this
video:
http://www.youtube.com/watch?v=pX3mlGMCagU
At 01:00 or so, they demonstrate the patch/spline functionality. MOI already rocks, but if you could add functionality like that,
and make it possible that the results are solids, you will surpasss T-Splines by far!
@K4IY Mike: Thank you so much for your effords, and it seems as if your last suggestion (the boolean approach) is
the one which gets close enough to the desired solution. One more question: The two stumps at the origin of the "claws"
are curves which can be used in a sweep or a cureve network for constructing the claws onto the base?
@ to the rest of you all: Thank you so much for your support, i hope i can return the favour one day!
Best regards
Heiner
5791.10 In reply to 5791.9
Great deal, Heiner!
I believe so, any edge of any surface should have useable curves.
You could sweep those curves further, or even use Blend to create 'transitional' surface patches to existing claw shapes.
The best course may be to consider the whole object when forming the surfaces that make up the overall curved shape.
Maybe at least with the larger of the two claws, you would have carried the main top and bottom surfaces through the whole course, then worried about the smaller one later.
This way, the overall feel of the shape would be continuous.
5791.11 In reply to 5791.9
Hi Heiner,
> T-Splines by far!
In the future I'd like to experiment in that direction, but point cage manipulation and sub-d type tools use a much different toolset than NURBS modeling, and there is still quite a bit of work that I have left to do to improve things just in the area of NURBS modeling alone...
There are already a lot of tools out there for doing sub-d modeling and so that also means that it kind of makes more sense for me to focus in somewhat different areas rather than just trying to do the same as sub-d modeling, if MoI just gave you the same tools that you already have, it wouldn't really be giving the same kind of value- it's more when a tool does something that was very difficult to do in your other tools that it becomes more valuable.
It looks like Mike's approach focusing more on building the body and the arms separately and using more 2D curve techniques for cutting the body is a good way to go.
Basically NURBS modeling is strongest in the area of using 2D curves to build your model - if you're finding yourself doing all swoopy 3D curves all over the place usually that's a sign that you're trying to use polygon modeling techniques instead of really driving things by 2D profile curves which is where NURBS is best at.
Sometimes it takes a while to get used to using 2D curves in your workflow also as cutting profiles, a lot of polygon modelers are so used to forming everything directly by points, but instead in NURBS modeling you often want to build a base shape that is initially extended larger than your final one but then form some of the final areas by cutting that shape with 2D profiles, rather than trying to draw in all 3D profile curves all over the place.
5791.12 In reply to 5791.9
Hi Heiner,
** Your mentioning of T-Splines is interesting, because i am monitoring these for quite some time, but was not able to raise the funds
to get them (Besides they are Autodesk now, which is a company i am not too fond of). **
Clayoo is supposed to be very similar to how T-Splines works, but without the Autodesk association.
http://www.clayoo.com/
HTH, Colin
5791.13 In reply to 5791.8
Hi Mike,
i was working on the model yesterday, trying to apply your workflow.
Basicly it works fin, but i can not figure out, how you get the slope applied
to the top surface?
Can you explain that a bit more in detail?
Heiner
5791.14 In reply to 5791.13
Hi Heiner,
Moi3D makes curved surfaces easy!
One way is to draw a curve in one of the side views, then use the Extrude tool make the curved surface.
You can of course add or move the control points during this process.
Now if you want to get really fancy, you can make a surface that has a more complicated curviness to it in all directions.
You'll need a simple set of curves, roughly placed together to form a framework.
You can draw them in multiple views, and then adjust the control points of each curve to represent the form in any particular area you wish.
The number of points can vary just as the curviness.
Use the Network command to make a new surface that has a curving form in all dimensions.
And now you can go further and actually manipulate the control point grid within your new network surface to add protuberances!
In my example earlier, I simply used a basic surface Extruded from one curve, but the process can be scaled.
Show messages: All  1-7  8-14
