Screenshot with Mac / MoI v3 beta Mar-17-2013
All  1-3  4-6
5782.4 In reply to 5782.3
Hi Moritz,
> I'm sure you will fix that problem before sunset ... :-}
I'm away on vacation for this next week (still on e-mail and such but not at my main dev machines) so I won't be able to really look into this problem until I return, and it will likely take until the next v3 beta release, sorry.
> And the "Mr. Spock"-grip cmd-shift-4 on the mac forces my to
> rename each screenshot separately.
Ok, but each rename is not particularly time consuming, this method should work for getting the job done currently.
There are also some other varieties of OSX system screenshot methods listed here:
http://graphicssoft.about.com/od/screencapturemac/ht/macscreenshot.htm
And probably if you look around I'm sure you could find a screenshot utility that would prompt you for a filename when you push a hotkey rather than auto naming it.
5782.5
To throw in my 2 cents; I don't use the script (although it does work in OS X). I much prefer to use the built-in OS X app called Grab. You have the options of capturing an individual window or dialog box, the whole screen, a timed screen shot or you can make a selection. If a person wants to get "fancy", an Automator script can be used to name and place screen shot in a particular folder. I no longer go to that length, but I use Grab with every project to capture MoI model views and then bring them into PhotoShop to quickly place them on a uniform background.
Michael Cramblet
Packaging Design
Phone: 616-574-6271
Size: 348 KB, Downloaded: 76 times, Dimensions: 1280x720px
Size: 78.9 KB, Downloaded: 77 times, Dimensions: 469x996px
5782.6 In reply to 5782.5
that's a practical suggestion.
Thanks a lot
Moritz from Germany
Show messages: All  1-3  4-6
