Scale and Adobe Illustrator
All  1-4  5-9
5779.5
Thanks for all of your help. Syncing the units did the trick.
One last related question if I may? Once you have drawn an object can you select it, query its dimensional properties and perform a numeric transformation? Simply put can you change an object dimensioning numerically after the initial creation?
5779.6
With the object selected, click the size to open edit size input.
5779.7 In reply to 5779.5
Are you talking about Options, General, Unit system, unit options, to change from say inches to centimeters?
5779.8 In reply to 5779.7
Yup, you can set the current unit system with the dropdown at the top of Options > General, and if you want to change the default units that MoI uses on startup you can do that one by pushing "Unit options".
5779.9
Excellent! Now I am in business thanks to all of you!
Show messages: All  1-4  5-9
