V3 beta Mar-17-2013 available now
 1-12  13-32  33-52  53-71
5774.13 In reply to 5774.11
Hi Denis,
> I love the new beta, running fine with the new multi touch on the Samsung 500t model.
That's great news! There are some various settings available under Options > View > Rotate/Pan/Zoom settings > Multitouch section, and also a couple of other customizable things in moi.ini too, I'll get a whole list together tomorrow.
5774.14 In reply to 5774.10
Hi DesuDeus - now I remember the other new option that's in there that you had asked for, it's one for showing hidden lines only on selected objects instead of showing all hidden lines.
It was a lot more complicated to implement than you might think, since it involved various different things like hit testing, selection, and not just purely display.
But it's in there now, you can turn it on in the Options UI under Options > View > "Hidden edges on selected only".
Also you can flip it on or off by putting this script on a keyboard shortcut:
script: /* Toggle using hidden edge display for selected objects only */ moi.view.hiddenLinesSelectedOnly = !moi.view.hiddenLinesSelectedOnly;
When it's turned on you will only see and snap to and select hidden edges on selected objects when hidden edge display is enabled.
ArrayGem now works with point targets.
5774.16 In reply to 5774.14
Whoa!
This could be interesting... I can dig it. The ability to see the full hidden line detail only on the object you're working on.
So... maybe ArrayCircular might someday allow you to pick a two-point rotation axis in 3d-space rather than just one point that rotates on the current view or C-plane? ;-) Sorry, had to plug it.
I've been working on gathering up the full release notes, there are a lot of other little bug fixes and various requested things in this version. I hope to have the notes finished up tomorrow, sorry it's taken a while.
5774.18 In reply to 5774.17
Hey Michael - Relax dude, it's beta-ware, it's fluid and subject to change!
Have a good trip and enjoy the Easter weekend if you celebrate it ... or not :)
Martin Spencer-Ford
5774.19 In reply to 5774.18
> enjoy the Easter weekend if you celebrate it...
Michael, give your bunny plenty of food and rest Monday, he'll deserve it. ;-)
5774.20 In reply to 5774.17
One thing that I did notice about the Mar beta is that imports work much better than in the other two.
There were several models, some SW native others IGES & STEP, that I had to play with in MoI 2.0 because the V3 beta would not open them.
Mar 18 release runs perfectly on that regard. I don't know if you actually worked on the import engine but something that was done made the import file work much better for me.
mjs
5774.21 In reply to 5774.20
Hi mjs,
That's great news - this version has been updated to use the latest library version for IGES, STEP, and SAT transfer which has some bug fixes in it, and also I've fixed a pretty low level bug in Solids++ involving coincidence checking between closed edge curves which probably helps out some join problems.
Anyway, I'm glad that this release is improving in this regard.
Still need to collect info on multi-touch and nsided, but here are all the other notes aside from those things (I will add these to the first post as well):
Updated relative tolerance handling for small objects - make the small object relative tolerance to be 1e-4 of the bounding box diagonal rather than 1e-2 as it was previously. This should help small objects behave more like regular sized objects in things that use relative tolerance. Also made a mechanism that additionally tightens the tolerance by up to 1/100 more if there are small sized features within the object. Fixes a boolean bug reported on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5535.1
Updated curve offset - fixed having the command processor being re-created on every mouse move, which improves curve offset display performace especially on Mac.
Updated DXF export - Enable writing point objects to DXF format, and also fixed a crash bug reported through e-mail when using cubic splines export option with degenerate projected curves. Also don't send out degenerate projected curves at all which fixes importing into one particular version of AutoCAD that was sensitive to that.
Updated IGES, STEP, and SAT IO library to latest version.
Updated viewport scripting - added properties .pixelWidth and .pixelHeight on a viewport so that it can be possible to take the current viewport's size into account when doing something like a screenshot.
Added script interface for getting or setting the active style: moi.geometryDatabase.activeStyle
Added a new moi.ini flag to disable file caching under [UI] DisableFileCaching=n . When set to =y it will prevent MoI from caching scripts and UI files in memory so that they are loaded from disk on each use, this can help when you're working on doing some development with those files and you want to frequently test changes in them.
Updated Align command - Added a checkbox to the Align command for "Move as group", which is visible when multiple objects are selected for the align. When enabled it causes the objects to move as an entire set to their overall bounding box rather than each one moving individually. Requested on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5533.1 . Also fixed a bug in Align where object alignment did not use a custom cplane properly.
Updated Transform > Copy command - added a command specific Undo action for the Transform > Copy command so that hitting undo while in the command will remove the last placed copy. Requested on the forum here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=5524.89
Fixed a bug in Solids++ in the curve coincidence checker when dealing with 2 closed curves. Helps to avoid some edge fragmentation that could happen previously and fixes an Inset bug reported in the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5508.1
Update face domains as part of the default processing when a brep is added to the geometry database. Some Solids++ routines would not set the face domain and it was left the same as the surface domain, while on loading a 3DM file MOI would set the face domain to the bounding box around the UV trim curves. This difference in face domain could occasionally lead to slightly different behavior in intersection calculations, with things working better after doing a save and reload. This update should now give better consistency between how things behaved in a loaded file versus an in-session created one.
Fixed a selection bug where selecting just one curve and doing Join would deselect the curve but the edit frame would stay on the screen. Fixes a bug reported on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5524.97
Updated chamfer UI - fixed a word wrap bug reported on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5524.99
Fixed a bug for 3Dconnexion devices on OSX with multiple model windows open - previously the 3Dconnexion device would only work properly when there was only one window.
Added 3Dconnexion setting in moi.ini: [3Dconnexion] Swap3DViewPanZoom=n . This can be set to =y to swap pan and zoom motions for the 3D view only. Requested on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5574.1
Updated 3DConnexion / simultaneous mouse move behavior. Delay mouse move processing until at least a small amount of time has passed since the last 3DX event - helps reduce jerky viewport movement for some cases.
Updated control point editing with analytic surfaces - After control point editing, if the previous surface was analytic or the new surface is planar, try to create an analytic surface for the new result. Fixes a bug with inset after control point editing reported on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5583.1
Updated extrude to point - If the base curve is an arc or circle shape, try to make an analytic cone out of the result. Fixes a bug reported in the forum here with trying to offset the result: http://moi3d.com/forum/index.php?webtag=MOI&msg=5524.110
Updated properties panel arc resizing - don't look at closed curves when scanning for touching endpoints for an alternate origin for the scale. Fixes a bug report on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5524.113
Fixed a scene browser bug where editing an object's name where only the case of the letters changed between upper and lower case did not trigger an update in the scene browser's object section. Fixes a bug reported on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5635.1
Updated OBJ export settings - added a new setting in moi.ini for OBJ export to help with mesh transfer into Rhino. [OBJ Export] WriteStylesAsGroups=n When this is enabled by changing to WriteStylesAsGroups=y then the style name will be written as the group identifier when generating the mesh. This allows for using the setting in Rhino's OBJ importer for importing groups as layers to get the mesh back to the same layer as the original object. Requested in the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5637.1
Updated filtering - when a curve is filtered out from selection, don't draw it at all in the hit test map so it won't occlude edges which may be the filter targets. Fixes an edge selection bug reported in the forum where with edge filtering turned on the edges were still unselectable if curves were on top of them: http://moi3d.com/forum/index.php?webtag=MOI&msg=5732.1
Update selection - fixed regression bug introduced with the Flow command, where post picking for extrude did not allow drill-in to select edges on a box because it took the clicked-on face immediately. Reported on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5732.1
Update hidden edges display - add a new checkbox setting in options dialog for controlling whether to show hidden edges on selected objects only, under Options > View > "Hidden edges on selected only". When enabled hidden lines are only displayed for selected breps only instead of on everything. This can help to disambiguate snapping onto or selecting hidden lines when there are many objects involved. This can also be toggled by script using:
Implement view spinning - Add a script method for view spinning that can be set on a keyboard shortcut:
script: /* click and drag mouse to spin view */ moi.view.spinInteractive();
This allows for tilting/spinning the view using a mouse or tablet if no multi-touch is available.
Updated OSX crash reporting. Put moi_report.zip files into ~/Library/Logs/DiagnosticReports/ and also try to generate an OSX system crash report .crash file as well which goes in that same folder.
5774.23
-> Updated viewport scripting - added properties .pixelWidth and .pixelHeight on a viewport so that it can be possible to take the current viewport's size into account when doing something like a screenshot.
Ok this is really useful for me ! How I do a script that capture the exact viewport (maybe 2x the pixel size for better antialiasing later in photoshop) :)
Thanks for all the new things, there's a lot of changes in the beta that's great :)
shapenoid.com stojan-voumard.com
5774.24
Thanks for all your efforts Michael.
I don't get to spend as much time with MoI as I like, but when I do I am sure glad that I have it.
I sure appreciate how you present the beta versions, always keeping users up to date with your current achievements.
Keep up the great job!
_________________________
Don Cheke
Visit: Textual Creations
5774.25
Michael.
Thank you for another super update to the MoI beta.
Something may be escaping me, but is it intended behaviour that the new 'Hidden edges on selected only' option only kicks in when 'Display hidden lines' is also selected, as that's how it's working for me?
To clarify, I think I was expecting the two to work independently, as well as in combination with each other and at the moment I can't see why that isn't the case.
Cheers.
Martin (2)
5774.26 In reply to 5774.23
Hi DesuDeus,
Can you post your current viewport screenshot script, and then I will see about modifying it for generating 2x the current pixel size.
5774.27 In reply to 5774.25
Hi Martin,
Yup, that's how it's supposed to work. It modifies the hidden edge display - if hidden edges are not being displayed at all then there is nothing to modify.
So "Display hidden lines" controls whether hidden lines are being displayed at all. When they are being displayed, there are 2 different ways they can be displayed - on everything (same as before) or only on selected objects, controlled by the "Hidden edges on selected only" option.
5774.28 In reply to 5774.27
Michael.
With regard to keeping a clean screen in complex drawings - and providing it's even possible, do you think it might be an advantage to have the new 'Hidden edges on selected only' option also work independently of whether 'Display hidden lines' is ticked, so that the highlighted parts are the ONLY ones to display as hidden edges/lines?
The reason I ask is because I tried out the new feature on a drawing which contains curves that are submerged into or behind a solid, and it would have been helpful for clarity and ease of snapping, if these (unselected) curves had not been visible alongside the edges of the selected solid.
Thanks again for all your work and quick replies.
Martin(2).
5774.29 In reply to 5774.28
Hi Martin,
> <...> so that the highlighted parts are the ONLY ones to
That is how it works currently - if you have it enabled only edges of selected solids or surfaces will be get the hidden line display.
This new setting does not have any effect on "standalone curves" though, meaning curve objects like a drawn line or circle or something that are not edges of a solid or a surface.
It didn't really seem to make sense to apply this setting to selected standalone curves, because selected standalone curves already draw on top of everything so selected curves do not get drawn in the hidden-line style at all.
If the unselected hidden-line curves were getting in your way your best bet would be to just temporarily disable the entire hidden-line display, there is a shortcut for that in the View palette in the side pane, you don't have to go all the way into the Options dialog for that one.
Or just in general if stuff is getting in your way you can select it and hide it to get it out of the way.
But basically this new mode is to help manage edges not standalone curves - usually it's normal to have a lot more edges being displayed on screen than curves.
5774.30 In reply to 5774.29
Hi Michael.
Sorry to come back again, but I don't know if I made my point very well before.
This is how I think it could work better for me.
Switch off 'Display hidden lines' and switch on 'Hidden edges on selected only'. Then, when selected, only the hidden wireframe edges of parts would be visible and snap-able, and would clear the display of all the other hidden lines/curves that I'm not interested in at that moment.
Here's my video attempt to help explain what I mean, by showing the wireframes of just the block and surface (by keeping the mouse button pressed) whilst noticing that the lower portion of the red circle remains unselectable by the 'Display hidden lines' being turned off.
http://screencast.com/t/BqcmuRuIdkpI
 Thanks for looking again.
Martin(2).
5774.31 In reply to 5774.30
Hi Martin, I'm sorry I'm still not entirely sure if I understand you correctly.
> and snap-able, <....>
Ok, so you're saying that when "Display hidden lines" was turned off, there would still be some hidden edge display being shown? If so then that's problematic that the setting would seem to say that no hidden lines would be shown yet you are talking about showing some...
I think it's pretty important to be able to turn off the hidden line display entirely, that's what happens with the first "Display hidden lines" checkbox being on or off. There is also a shortcut for that under the View palette. It's useful to be able to totally turn off the hidden line display in just one spot because if you have some hidden lines cluttering up your display it lets you definitely clear them all by going to just one control and clicking it.
That's why the new "hidden edges on selected only" only modifies how edges are displayed _if_ hidden edge display is enabled, it allows you to still totally disable all hidden lines by using the other "Display hidden lines" checkbox the same as before.
Hopefully the new option for also controlling the hidden-line display of edges only on selected objects will help to manage them in some situations without needing to do a full on or off, but I think it's still a good idea to have a sort of master on/off switch still though.
5774.32
Magnificent amount of work Michael!
This is awesome!!!
It really works great as a companion to "Free Rotation" view manipulation mode!
After 'spinning', the only way I've found to reset the view back to the original horizontal-0 if this was implemented in "Rotate Around World Axis Z" mode is to switch to "Free Rotation" mode then back to World Axiz Z, where the view port will reset.
But yes! You can now rotate the 'ortho' viewports which helps you to get a better look at your work.
Reset the spin angle in ortho views by clicking on its your current view's activation button twice... (right>left>right) Cool!
Also, would it be someday feasible to implement 'Spin' with other viewport manipulation methods, such as with a View Control button for fine-tuning, or maybe a way to do it on the fly with mouse manipulation?
Thanks!
EDITED: 24 Mar 2013 by MAJIKMIKE
Show messages:  1-12  13-32  33-52  53-71
