union failing
All  1-8  9-15
5769.9 In reply to 5769.8
Hello Michael,
thanks a million :) both for the model and guidance - must learn how to use the ShrinkTrimmedSrf.
BTW Should ScaleArray work ok in MAC as well (so for no luck with that)?
br Ari
5769.10 In reply to 5769.9
Hi Ari, you're welcome! re: ScaleArray - I think that should be working on the Mac too. But in order for it to work you need to include a point object (Draw curve > More > Point) along with the arrayed objects, it then uses that point as the center of the scale. Is it possible that your array items did not include a point object like that?
5769.11 In reply to 5769.10
Hello Michael,
I have the point object ok - there is an error message:
ReferenceError: Can't find variable: ScaleArray
line 1
1: >> ScaleArray
I have created a 'commands'-folder and added the ScaleArray.js and .htm there - is there something else I should do?
br Ari
5769.12 In reply to 5769.11
Hi Ari - you shouldn't have to create a commands folder, there should already be one there with all the regular commands (like Line, Extrude, Sweep, etc...) all in there already, you need to put those ScaleArray files into the same spot as all the regular commands.
So I think you probably don't have it in the right folder - when MoI tries to execute a command and it doesn't find any files of that name in the commands folder, it tries to execute the text as inline script code, that's what generates that particular error message that you're getting.
To get to the right commands folder on the Mac you need to right-click on the app and pick "Show package contents", then inside there go to /drive_c/moi/commands - that's where you'll need to copy the files into. Once you do that then you should be going ok.
5769.14 In reply to 5769.13
Hello Michael,
and so it was :) Thanks again - now I'll stop bothering you.
br Ari
5769.15 In reply to 5769.14
Hi Ari, well definitely the plug-in installation mechanism is pretty crude right now, particularly on OSX where you have to do that right-click and go down in there a ways.
In the future I want to totally overhaul that whole mechanism and have something like some built in UI to browse a repository of plug-ins. There is quite a bit of work involved in that though, and since you only have to do the clumsy copy step just one time and not on a daily basis or anything it just hasn't risen to a high priority yet.
Show messages: All  1-8  9-15
