problem with extrusion
All  1  2-11
5733.2 In reply to 5733.1
Hi Raoul:
i'm courious too ..in the meanwhile,using -REBUILD- for outern contour with 0,01 default tolerance you can extrude in both directions
5733.3 In reply to 5733.2
Hi m-dynamics,
Thanks for your input.
I just tested myself and indeed, rebuild is the work-around in this case.
Curious to know what it is. I also tested in release 2, but the effect is the same.
Kind regards,
Raoul
5733.4 In reply to 5733.3
hi there!
i spotted a few tiny hick ups in the outer profile..well, 8 of them..
after cleaning those "irregularities", everything is working as expected.
~ marco
EDITED: 24 Feb 2013 by MARCO
5733.5 In reply to 5733.4
Hi Marco,
I cleaned the hick ups and yes, the extrusion is without problem now.
Thanks.
Raoul
5733.6 In reply to 5733.4
Hello,
The file is attached with extrusion, just create a plan and make an boolean opération to remove a center part
-Kaël
5733.7 In reply to 5733.6
It is true that there are some errors to connecting line
5733.8 In reply to 5733.5
Also note that the profiles are not "flat" or planar. There are out by a very miniscule amount, which can be throwing a tolerance mechanism out of whack.
If you switch to a side plan view and drag one of the edit frames corners towards the other, you will see a "flat" snap appear. Then the file is good as-is (But surely you want to fix the little pieces also)
You may want to review how your profiles became so messed up in Z. Usually, this is a cause of using some type of "make2d" command. This type of output really needs to be looked at before continuing.
5733.9 In reply to 5733.8
BurrMan, you are right. Although I thought the curves were 100 % upon a XY planar surface, it is not exactly.
I projected the curves to a new XY-planar and used that new projection for extrusion. Now the whole problem is solved.
Thanks all for your help!
Raoul
5733.10
Hello,
Here is the zoom of défaults
-Kaël
Size: 359.6 KB, Downloaded: 55 times, Dimensions: 1680x1050px
5733.11 In reply to 5733.9
Raoul:
<<BurrMan, you are right>>
He is ALWAYS right...
Raoul:
<< I projected the curves to a new XY-planar and used that new projection for extrusion. Now the whole problem is solved>>
I use same trick in cases like this,where there are too many points to check if -REBUILT- not give results
i think in this case -REBUILT-has cutted away not-planar points...
Show messages: All  1  2-11
