how to finish the top on this object
All  1-8  9-14
5728.9 In reply to 5728.8
Hi blade33ru, Rhino has a lot more commands than MoI for doing all kinds of specialized stuff (including more advanced blends right now), but there isn't really any difference in the particular area of history parameter editing. MoI and Rhino are basically about the same in that area, it's also not an area that Rhino is particularly focused on either.
5728.10 In reply to 5728.9
i like parametric...on the other hand the simplicity here is key...this is the most productive ive ever been with nurbs...usually I get clogged down in the interface.
i followed that other thread of curved surfaces you out up to create this shape ...it was really easy.
i cant tell you how pleased I am!.
this could be a good educational product to teach modelling concepts...i teach classes in maya and pretty much no one is teaching nurbs in the visual effects fields anymore, but i know students would dig this a lot...they get pretty lost trying to maintain proper edge flow and adding extra edges for detail. this is so much more direct and logical
also i was thinking, alot of the world has moved to subds for modelling pretty much everything, but there are great advantages with nurbs for this kind of stuff...with number one being its really easy. still it would be useful and maybe marketeable to retain sub d concepts like edge loop and edge ring selections but to tangent curves or nurbs edges as we have here.
great product this
scott turner
www.republicavfx.com
5728.11 In reply to 5728.10
Hi scott, yeah the main focus for MoI is on getting things drawn really quickly and fluidly.
Usually other CAD programs that focus on history have a lot of additional setup stuff that you have to do as part of the workflow, like before you can draw you have to pick a drawing plane, engage certain modes, and stuff like that. There is typically more process involved. That can pay off down the road for making adjustments but it can also tend to really stifle just the basic drawing and initial creation process, sometimes making things complex enough that the whole program requires quite a bit of training in order to operate.
MoI is set up to try and bring the primary beneficial essence of NURBS modeling (which is basically building shapes primarily by 2D profile curves) to be more approachable.
It can be a great companion to sub-d modeling because a lot of man-made objects are very well defined by 2D profile curves, and have cut out areas which can be very labor intensive to model with sub-d techniques where to make even a basic hole you have to be a kind of master of topology. With NURBS modeling to make a hole you just draw a 2D curve and do a boolean.
Really the NURBS process is strongest when you're using 2D profile curves for the majority of your work other than selecting edges for filleting. The overall workflow is really different from sub-d so it's not really that feasible to try and make it resemble sub-d, it's a completely different kind of technique.
But that difference is also why it can be useful as a companion since it can just do a better job (more quickly and easily and also more accurately) of certain kinds of shapes.
If your model is more organic or semi-blobby in shape then that becomes a better fit for sub-d modeling techniques. The more that your model is strongly defined by 2D profile curves with holes or cut out areas in it the more it becomes suitable for NURBS modeling techniques.
But the overall approach of NURBS modeling is pretty different than sub-d - you want to rely on 2D curves a lot more and also rely on booleans and cutting operations as a primary way of doing things. That can take a little while to sink in for people from a sub-d modeling background who are used to avoiding booleans at all costs. Instead with NURBS modeling often times building things as a simple extended piece and then using booleans should be the main approach.
Check out here for some links to discussions and general tips for people who are coming from a sub-d / poly modeling background:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
5728.12 In reply to 5728.11
hey thanks for all the info ...very useful...
u might be interested that i just installed a demo of autodesk inventor and was pleased to see they extend the idea of edge loops into their nurbs modelling environment. a small detail but it works nicely. still for 8 grand maybe i can live without it, lol
scott turner
5728.13 In reply to 5728.12
Hi scott, yeah there are a few NURBS modelers that try to incorporate sub-d modeling techniques by giving features to start with a block and then squish it into some completely other shape.
However, that general overall strategy is not really where NURBS truly has its greatest strengths. If you are trying to model that way in NURBS you probably should just be modeling in a sub-d program instead where the whole package is totally oriented around sculpting and organic shaping.
NURBS modeling has its greatest strengths in the area of generating surfaces and cuts from drawn profile curves (I'd compare it more to "illustration" or "construction") rather than in squishing things around (which I'd compare to more like "sculpting"). If you try to do the same kind of process in NURBS as you do in sub-d you're not really gaining that much since you already has that kind of process covered very well in your sub-d modeling tool, in order to gain the greatest benefits of a different tool you have to more embrace that there is a different workflow orientation to it.
If you're looking for no change in workflow the easiest way to achieve that is to just stick with what you've got already rather than trying a new tool in the first place.
So in other words, I'd recommend looking at differences in workflow and modeling strategy to be a good and useful thing, not really a defect! ;)
5728.14 In reply to 5728.13
interesting points. thank you!
scott turner
Show messages: All  1-8  9-14
