Any Sneak peek of the next beta ?
 1-9  10-29  30-49  50-53
5721.50 In reply to 5721.17
I think it will probably be called NSided.
Does it really have to be a seperate command ? I mean it looks really close of the blend function for me, on steroid.
I'm pretty sure there are reasons you dont merge the 2 functions ...
5721.51 In reply to 5721.50
Hi PaQ,
I may still attempt to do something like that, but the problem is that it could be possible to give regular 2-sided Blend a similar set of inputs when the 2 sides touch each other at their ends.
When 2 functions can take the same inputs but do somewhat different things with them that's when it can be difficult to combine them in one single command.
5721.52
All this looks great, Michael.
I sorta dropped off for a bit cause I know for a time, you were mostly focused on the Mac build, but this is that kinda stuff that grabs my attention every time!
Great work!
-Will
5721.53 In reply to 5721.2
You really are a wizard with the new routines Michael, the NSided function or routine really does add more organic modelling to Moi, which is a boon for 3d sculpture work.
Hats off to you in the development of Moi Michael, it really is a "Moment Of Inspiration" that should not be missed..
Show messages:  1-9  10-29  30-49  50-53
