feature request: temporarily suspend history update
All  1-2  3-6
571.3 In reply to 571.2
thanks for your response, this sounds very promising.
571.4 In reply to 571.3
Hi Michael, well it wasn't easy but I just finished the history canceling / updating stuff which will be in the next beta. I'm not sure when the next beta will be ready, maybe the end of next week.
Now the immediate object that you are editing stays responsive when you drag the mouse around, and history updates will happen if they can be done within a short time period, or otherwise they get automatically canceled and a new history calculation is started. If you hold your mouse still for a moment you can let it "catch up".
When you finish an operation, like for example when you release the mouse for a dragging operation, MoI will wait and finish computing the history updates then. If it takes a while, it will display "Calculating", and you can push the Cancel button or hit the escape key to cancel the entire operation if it is taking too long, which wasn't previously possible.
There is one negative side effect - there is a bit of overhead to having history be interruptable like this, so some simple things that previously updated really quickly will have a slightly less fluid feel. Like if you edit a curve, the curve itself will immediately move into its new place, but the history update will get there just a slight moment after. The history kind of "follows" the curve a little bit instead of moving with the curve always all in one single step like it previously did. It has a slightly different feel.
But the good part is that the thing that you are immediately editing stays fluid while you move the mouse around even if there is complex history attached to it. Things don't completely "lock up" while the history is being updated like it previously would.
571.5 In reply to 571.4
Hi Michael, i'm glad you got to work on this so quickly. Can't wait to check it out.
571.6 In reply to 571.5
The nice thing about this is that previously you may have hesitated to mess around with something with complex history if you thought it might go off and lock things up for some unknown length of time.
Having the ability to cancel with the next beta means that you don't have to hesitate like that anymore. It's still possible that it might take some length of time to finish calculating, but if you don't want to wait you can bail out, you're not just stuck there. So you can feel more free to experiment.
The only thing that is not quite "perfect" is that you do have to wait for history to be calculated after you finish any particular operation. Like if you drag a control point, history needs to be updated when you release the mouse to finish the drag. Although you can cancel it, if you want to accept that edit and do some more, you still need to wait for it to finish before you can do the additional operations.
Ideally it would be nice if you could go on to do several other operations, like drag some other points, etc..., without waiting for the update at the end of each separate operation.
It's going to be pretty complex to get that to work because of issues like what if one of your additional operations is to delete the curve... So that full level of fluidity will have to wait until a future version.
Show messages: All  1-2  3-6
